06-04-2018, 02:29 PM
#151
One passenger side shipped to 85020 please! And please hold onto two additional ones for me as we discussed in case I can make it work for the middle seats too (I’ll work on it this month and will let you know by end of the month)
Can I add a door talon and one of the fold down shelves for the aluminess boxes to my order too? You can wait and ship it all together, no rush.
06-04-2018, 09:04 PM
#152
I'd like to get a passenger side shipped to 80911.
06-10-2018, 09:55 AM
#153
PM sent, had a few additional questions.
06-10-2018, 03:52 PM
#154
I would like a passenger swivel base, Shipping to a business in 94515 Calistoga
Thank you, Bill
06-18-2018, 11:10 AM
#155
next group buy
I am new to this forum. I am interested in purchasing driver and passenger side swivel seat bases for my Ford E250 van. Can you give me any info on how this is done on your site or if there is one started. Thanks Ron
06-18-2018, 11:13 AM
#156
Hi Ron, PM me or post your zip. I wil get a shipping quote, payment and my contact info to you. This buy is wrapping up, so if you want in, please contact me asap. Thxs Ray
06-18-2018, 11:32 AM
#157
Thanks. My zip is 95062.
06-25-2018, 10:55 AM
#158
Hi Ray and the rest of the group on this thread...
I am new to the forum. I have been searching for a swivel for my 1995 4X4 Diesel Van. They do not seem to exist. Most units listed claim to only work on '96+ model years. I am not sure what changed in 96...
I am wondering whether these swivels will work on a 1995 model? If not, has anyone done any playing around with these to discover what modes need to be done to make it work?
Thank you all for your contributions and thoughts!
06-25-2018, 11:21 AM
#159
Originally Posted by 95 E350 4X4
I am wondering whether these swivels will work on a 1995 model? If not, has anyone done any playing around with these to discover what modes need to be done to make it work? Thank you all for your contributions and thoughts!
Here is a post from TomsBeast: A note to others with earlier vans: In comparing Ray's sketch with mine, above, it appears the lower plate is large enough to accept the narrower 1995 hole pattern. I plan to just drill 4 new holes and bolt it in place. I don't know about the other years, but I had seen a listing from some aftermarket company, where the part number for 1994 and 1995 E series was the same.
_____________
Here is a drawing of the seat base floor plate and seat track mounting dimensions. I believe you will have to drill new holes for the floor plate. I do not know if the seat tracks are the same. Please check yours and let us kno. Thxs!:
06-25-2018, 12:29 PM
#160
Hi Ray. Thanks for your quick reply. I have gone out an done some 'quick and rough' measurements. The bolt pattern for mounting to the floor is significantly smaller - ~9.5" wide at the front, ~7.5" wide at the back, and ~12" from front to back - so, as mentioned, drilling 4 new holes in the floor mounting plate should work fine.
The angle/rake seems similar (I roughly measured 5.5" at the back and 8" at the front), so that is reasonably close...
I found it really hard to measure the bolts mounting the base to the seat slides, but the dimensions seem to be quite a bit bigger than the overall plate dimensions. I am measuring, if I am measuring the right place, close to 15 1/2" wide both front and back and 13 3/4" from front to back. That is considerably wider than the mounting plate in the diagram. I think to be sure, I may have to remove the seat and take it apart to be sure of the measurements...
I see that you just completed an order. Any thoughts on timing for another?
Thanks again for your input and thoughts.
