Another BUMP For the SWIVEL SEAT BASE GROUP BUY , I am placing the order today and will order some extras for late comers. The extras are available on first paid basis.
Let me know asap!! Thanks!
Right now looks like three passenger seat bases and one driver base are available for shipping next week. Let me know. First to pay is first in line. Thanks!
I'm all paid up so I guess it's on the way. Thanks 1der. Dropped the Van off at CCV with Derek this morning. So I have till the 26th till it's ready...
You are all paid. Thxs!
I seem to have what I have determined via Google after removing my passenger seat that there is a small part, which the Googles says is Yaw Sensor. It is directly below the seat on my 07 EB350. This sensor has a hollow triangle piece of plastic on the bottom of it and does not sit flush on the floor of the van. There is a groove in the van floor to accommodate this extra piece on the yaw sensor. However, it does sit directly in the way of the base plate of the seat swivel. Can this be repositioned? I saw no mention of anyone else having an issue of this sort?? What to do?
Ok so I had to move that Yaw thing. I removed it from the floor. I drilled it into a wooden base with a space cut out for the weird plastic bottom piece and then pulled the anchor points from the floor for the wires all the way to the back of the seat area. From there I reattached the yaw thing attached to the wooden block with a glue gun to the top of the base. I also rerouted the wires to pass through the middle area by the handle instead of the back to keep the wires from pulling when the seat rotates. Here are some photos hope it helps if anyone runs into a similar issue.
Yes...par for the course, my install challenge was even new to 1Der who called me immediately upon hearing of my escapades. But, it looks to be good to go. I may clean it up a bit when I redo the floor but it's good for now!
