Old 11-26-2019, 11:19 PM   #1
4 Grand Van
I spend most of my time on Expo, but I bought a van! And so here I am... It's a 2003 e350 Super Duty, 7.3 PowerStroke with 250,000 miles. In great shape, everything works except a possible AC leak and bad blend door. And possibly something with the EGR or a vacuum line cause the service engine light comes on during long uphill grades but turns back off on the way down.
Currently a lowly cargo van - it's going to stay that way for some time while we use it as a work van as we renovate a new (100-year-old) home. Eventually, a 4x4 conversion, pop top, and a mild interior build should happen- but for the meantime it will haul plywood while I gather ideas from all the awesome posts I find here!
Sent from an evil pocket calculator with a flashy screen
furbucket is offline   Reply With Quote
Old 11-27-2019, 04:33 AM   #2
marret's Avatar
Congrats and welcome. Looks like a great base from which to build and will of course work great supporting your home renovation.
Chris
Old 11-27-2019, 09:31 AM   #3
Welcome. There are plenty of threads here about blend door repairs. A scan gauge will tell you what codes are setting the check engine light. Cheers.......
Old 11-27-2019, 10:47 AM   #4
Drizzt's Avatar
250k. Just getting broken in.
David
2003 E350 | 7.3PSD | U-Joint 6" - The Slow Build
Drizzt is offline   Reply With Quote
Old 11-28-2019, 10:19 AM   #5
4 Grand Van
Thanks for the replies - can’t wait to get started!
Old 11-29-2019, 08:35 AM   #6
"bad blend door" Is the dash air stuck on defrost regardless of dial setting?
Old 11-29-2019, 08:13 PM   #7
Heater only works on “vent”- when on other settings the cab still gets warm, but there is no discernible air movement from the floor, the defrost or anywhere...
A/C modes have air movement but not really COLD like it should be, my guess is a possible leak and/or needs a recharge...
Babe
Babe
Benz Tent
Chargersflyer
