Old 03-10-2013, 07:19 PM   #71
Re: Hola! My official introduction - 2002 White SMB EB50 7.3
Is it totally straight? Because mine is smaller tubing I really didn't notice it untill you pointed it out.
Old 03-10-2013, 08:54 PM   #72
Hola! My official introduction - 2002 White SMB EB50 7.3 4x4
Not totally. Off a little but most likely you'd have to point it out. Day and night though when compared to before.
If I had to do it all over again I'd go smaller tubing, low profile and expanded metal over the slats for weight consideration and sleeker look.
Old 03-10-2013, 10:24 PM   #73
buckkiller's Avatar
Love the rig bud...every time I see it wish mine was done
Sent from my DROID RAZR using Tapatalk 2
"The Redneck Mexican"
2002 E350 EB 7.3 Clydesdale 4x4 w/8' lift,
Colorado Camper Van pwr top,
Van Specialties build out
buckkiller is offline   Reply With Quote
Old 03-11-2013, 06:39 AM   #74
Thx buck. Hang in there dude.
Old 03-11-2013, 08:04 AM   #75
4MacFam's Avatar
If you wire in series you'll double the voltage (17v to 34v) and burn out your solar controller (max 30v). Wiring in parallel will double the amperage (8a to 16a) but that's ok since the controller can handle up to 25amps.
Positive to positive, negative to negative.
Is this what can be done? I'm having only one panel installed and if it works great in Wisconsin I might add another. I want to be able to connect positive from one panel to positive of second, then neg to neg, without adding another set of wires to inside of van.
Speaker photo, but same idea.
thx for advice to newbie.
Steve
Steven McKenzie
Madison, WI
2013 E350 EB-44, V10 6.8ltr
Toyo LT285/70 R17
Old 04-06-2013, 01:08 PM   #76
Hit a milestone.
Still ticking...fingers crossed
Old 04-06-2013, 04:38 PM   #77
Pschitt's Avatar
Nice! Where was it?
Old 04-06-2013, 09:51 PM   #78
Originally Posted by Pschitt
Nice! Where was it?
Alabama hills last weekend
Old 06-04-2013, 11:59 PM   #79
To do list
Old 06-15-2013, 05:10 PM   #80
Maxxima led work lights wired
MCSporty
MSD
MSH MBL
Skivvie
