View Poll Results: What's the general consensus?
Used 4x4 Sportmobile 3 100.00%
New 4x4 Sportsmobile 0 0%
Voters: 3. You may not vote on this poll
Old 07-13-2016, 04:21 PM   #11
The 50 is open and roomy plus gives you a lot of space to store stuff under and on the bed. But a walk thru model gives you access to the rear w/o having to go outside to open the rear doors. Most Voyager type tops have walk-thru type builds and those have a lot of overhead storage. As a big guy I feel cramped in a walk through Ford but the cutaway is a bit larger and depending on your combined size, the larger penthouse might be OK for two when sleeping up top. Maybe installing a Colorado Camper Van top on a used vehicle is worth a look-see.They have roomy space up top.
It seems to me if you're after a van that holds a couple of dirt bikes, finding a fully constructed build specific to your needs might be difficult to find used. SMB will add a top to a used vehicle in most cases but I haven't heard if they will do an interior build out on one...in the past they didn't.
Yeah lots of options. Do you really want to haul bikes inside? If I were building a vehicle to haul light motorcycles inside I'd be looking at a pop top with storage in the rear, a small galley with fridge, potable water tank/outside shower and a couple of swivel chairs so you can relax inside out of the weather.
If you frequent hotter weather and you want air conditioning, the larger vehicles are outfitted better for that. Just depends on what you really want or need. You can almost fit into anything depending how tight you want to make it.
Old 07-13-2016, 05:11 PM   #12
mikracer's Avatar
If I were full timing, I think I would want a fixed, raised top. You don't have to put the top up and down every time and you always have standing room. The only thing with your situation is the 2 dogs. Most high tops only have 1 sleeping area so if you have big dogs, it might get pretty cramped. If you get a pop top version, you usually have 2 sleeping areas.
Whichever you decide, make sure the bed is wide enough for you and your fiancé to sleep comfortably. The penthouse bed and the gaucho bed are pretty narrow for two people (in my opinion).
Old 07-13-2016, 05:37 PM   #13
...and
Good point.......If the OP is not aware of Colorado Camper van tops, something to consider.....SMB PH beds are 39" wide, CCV bed is 50" wide.....and you can sit upright in a CCV top.
Old 07-13-2016, 09:39 PM   #14
allenl's Avatar
Originally Posted by BroncoHauler View Post
Here are two threads I recommend reading.
How do you use your SMB?
http://www.sportsmobileforum.com/for...-smb-7253.html
Why did you sell your SMB?
http://www.sportsmobileforum.com/for...why-10382.html
The bottom line is really, really thinking about how you are going to use your rig, especially if you are going to full-time in it for a period of time.
Good stuff, thanks for the recommendations.
allenl is offline   Reply With Quote
Old 07-13-2016, 09:46 PM   #15
allenl's Avatar
Yeah, I hadn't run across the colorado camper van top. That looks nice. So far I really like the idea of the pop top for the extra sleeping room, but I definitely also understand the benefit of having a fixed top with constant room to move around in the vehicle.
And the penthouse bed is really only 39" wide?! Basically a twin bed width... this is a good point, thanks.
Old 07-13-2016, 09:48 PM   #16
allenl's Avatar
And the motos will definitely be on a trailer.
Old 07-14-2016, 07:05 AM   #17
Both tops are similar $$. CCV has a high and mid top.....member REF here has a high top and member 1der (and a few others) have the mid top. All of the CCV tops are electric. SMB are manual or electric.
Both companies offer a few variations of the bed......SMB has one piece and two piece beds for example, and Derek at CCV will do some minor customization as well.
I haul dirt bikes with a Harbor Freight folding trailer (or a Joe Hauler if I'm only hauling one) with a 5.4L without issue.
Old 07-14-2016, 08:07 AM   #18
If the bikes are on or in a trailer I'd go for a fixed top RB for the two of you, or if you have big dogs a fixed top EB.
Old 07-14-2016, 09:39 AM   #19
rallypanam's Avatar
...and
Even more dramatic than that.. Here's my measurements comparing my old SMB top to replacement CCV top:
http://www.sportsmobileforum.com/for...tml#post158595
Old 07-14-2016, 10:25 AM   #20
allenl's Avatar
Good reference, thanks. I haven't seen any used 4x4 Sportsmobiles with one of these CCV tops installed. I'm guessing that's pretty tough to find.
As much as I'd like the ability to stand without raising the lid, I like the lofted bed and the additional space it provides more. We've got 1 big and 1 medium dog, but overall they're space hogs.
SilVan
dhally
Big Backpack
RMAC
