Thread Tools Search this Thread Display Modes
DADDOZR
REDOVAL's Avatar
REDOVAL REDOVAL is offline
Vehicle Name DADDOZR
Year 2002
Make Ford
Model E350 Traveler
Color Med Parchment Metallic
Packages Traveler
2002 Ford E350 Traveler
2002 Ford E350 Traveler 2002 Ford E350 Traveler 2002 Ford E350 Traveler
History Former Ford Corporate transportation vehicle, purchased with 97k miles in original condition
V10
4R100 trans
Dana 60 Semi-Float
Leather interior
Exterior
2002 Ford E350 Traveler Exterior 2002 Ford E350 Traveler Exterior 2002 Ford E350 Traveler Exterior
Vantage Optics Projector Retrofit LED Headlights
IPCW LED Taillights
Weldtec Designs Cali Special front bumper
Custom front hidden hitch assembly
Profile RGBW LED rock lights, DD bluetooth controlled
Baja Designs S2 Pro lights on Vantage Optics pillar mounts
Baja Designs Squadron Pro XL spot pods on bumper
Baja Designs OnX6 30" LED bar on bumper
Larsen NMO HAM radio antenna mount w/ 5/8 wave antenna
Advaned Fiberglass fenders
05-up Power Towing Mirrors
C-Betr Blind Spot mirrors
Extended sliding door hinge
Move Bumpers rear plate bumper
Baja Designs Squadron Sport Reverse lights
Baja Designs Squadron Sport Flush Dust light
Bottle opener
reverse camera in license plate box
92-95 rear factory dark pop-out windows
Viair OBA with 444c compressors and 3 gallon tank
Diode Dynamics SS6 fog lights
Diode Dynamics SS6 third brake light
custom front hitch behind bumper
Powerpole outlets for winch and jumpers front and rear
110v shore power inlet
Interior
2002 Ford E350 Traveler Interior 2002 Ford E350 Traveler Interior 2002 Ford E350 Traveler Interior
Swivel pass front seat mount (1der)
LED gauge cluster bulb swap
SwitchPros switch panel
Blue Sea USB outlets
AUX input for radio in dash panel
Pioneer AVH-X3700 Deck
Panavise FO-300-01 phone mount
Mount on console for SCT XCAL4
Broadway panoramic mirror
Blue Sea cargo area USB/Cig lighter outlet ports
Pro Eagle Kratos floor jack and mount
Smittybilt winch with synthetic line
Factor 55 fairlead and closed winching system
PullPal sand anchor system
Tailgator Tire Table
Custom Vantage Optics water tank mounts in spares
15lb Powertank CO2 bottle and amerex 810 mount
Vantage Optics jack door thumbscrew kit
KC Cyclone Dome lights front and rear
shovel with Quick Fist mounts
traction boards
Blue Sea fuse panels front and rear
Element chemical fire extinguishers
two additional 5lb traditional fire extinguishers on quick release mounts
NAR CAT tourniquets
Wheels, Tires, & Suspension
2002 Ford E350 Traveler Wheels, Tires, & Suspension 2002 Ford E350 Traveler Wheels, Tires, & Suspension 2002 Ford E350 Traveler Wheels, Tires, & Suspension
Weldtec Designs Complete Performance Package
Sway-A-Way 2.5" reservoir shocks
Deegan 38 Pro 2 Wheels, 17x9 -12mm offset 8x165.1
Dick Cepek Extreme Country 315/70-17 tires
two full size matching wheel/tire combos in the cargo area
08-up front brake kit
Earls stainless brake lines
ARB air locker
Custom bump stops
Under the Hood
2002 Ford E350 Traveler Under the Hood 2002 Ford E350 Traveler Under the Hood
5 Star Tuning SCT XCAL 4 tuner assy
Tru-Cool 40k transmission cooler
Mobil1 synthetic oil
Flowmaster v-banded 3" muffler with turndown
Blue Sea fuse panel
PAC-200 and 500 aux battery isolators
ARB Air Locker
Dana Spicer 4.56 gears
2/0 battery cables and grounds
Odyssey Group 65 batteries
Redhead steering box
Vantage Optics header panel support brackets
Switch Pros SP9100 controller
Vantage Optics aux fuse holder
Systems, Solar, & Electronics
2002 Ford E350 Traveler Systems, Solar, & Electronics 2002 Ford E350 Traveler Systems, Solar, & Electronics 2002 Ford E350 Traveler Systems, Solar, & Electronics
Down4Sound JP23 and JP234ab purple amplifiers
Stereo Integrity SQL 15 subwoofers
CDT component speakers front and rear
Yaseau FTM-400XDR HAM radio (KN6BLB)
Cobra 75 WX ST CB Radio with 4' antenna
Rugged Radios RH-5Rv2 handhelds
Type S dash camera
Favorite Destinations
2002 Ford E350 Traveler Favorite Destinations 2002 Ford E350 Traveler Favorite Destinations 2002 Ford E350 Traveler Favorite Destinations
Mojave Preserve, Ocotillo Wells SVRA, Gorman, Cleghorn, Santiago Peak. Anywhere fast and rough
Old 05-16-2019, 12:35 AM   #2
Nice rig! Thx for sharing the details,I’m digging those hood brackets for pod lights,are those off the shelf or custom? The tow mirrors look great,are those pain to swap out or simple?does that 30” Baja Design’s light have two switches,one for amber and one for white or you just changed the lense out for that section? If it’s all 0n at the same time how do you like two different colors being thrown forward? Let me know if it’s cool join in one of your future rides,I got an 0/7 f150 4x4,thx Gustav
Zappo is offline   Reply With Quote
Old 05-16-2019, 09:51 AM   #3
REDOVAL's Avatar
Gustav,
The pillar brackets are available through Vantage Optics and work great for peripheral/ditch lighting needs.
https://www.vantageoptics.com/shop/V...kets-p73168518
The tow mirrors are easy for 2004-newer vans as they already have the correct mounts, but the 92-03 versions simply need one post removed and the others opened up a little. Not too bad of an install, but you will need time and a stepped drill bit and a few beers to wrap it up.
The BD light bar has one switch to control both the amber and white portions....I had the amber on in this version but have changed it out for all clear spot lenses for more high speed vision. The two colors work ok together, but I had the ambers on primarily for daytime use so others could see us better.
We will for sure need to do an outing, hit me up via email at stredbull18@gmail.com or through Vantage Optics at vantageoptics@gmail.com
Scott Thompson
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
