Old 08-14-2015, 11:41 AM   #1
AC fitting thread repair?
The male threads on my AC cooler (99 Express 3500) are bunged up and I need to find a die that I can use to repair these threads. I've already tried O'Reilly and Car Quest and they only have a 5/8" size.
Anyone know where I can buy or rent a die that will repair these threads or even what size/pitch these are?
1999 Chevy Quigley 4x4.
Damian is offline   Reply With Quote
Old 08-14-2015, 11:54 AM   #2
Zeta's Avatar
Re: AC fitting thread repair?
If there's anything left, you can try a thread file: http://www.ebay.com/itm/Jawco-1-Nu-Thre ... 58&vxp=mtr
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 08-26-2015, 11:32 AM   #3
That looks like a male insert o-ring braze-on fitting. You *might* be able to heat that up and remove it, then braze on a new one. I went through a similar problem on my 98 Express 3500, but I had broken a connector completely off. I found new ones here:
http://autoacfittings.com/5-8-Tube-x-Ma ... IOB-10.htm
There's several different sizes available, so you would have to look for exactly which one yours is, obviously.
Good luck!
capn
capnkurt is offline   Reply With Quote
