Adding 200lbs to Penthouse
Since I got Eli's awning brackets I decided to look at the Fiamma numbers a little closer:
f35pro 430cm: 14.1 x 7.4 ft -- 37.9 lbs
f45Ti 450cm: 14.7 x 8.2 ft -- 63.9 lbs
f45TiL 450 cm: 14.7 x 8.2 ft -- 81.6 lbs
f45TiL 500 cm: 16.6 x 8.2 ft -- 90.4 lbs
f45TiL 550 cm: 18.2 x 8.2 ft -- 101.4 lbs
There is a pretty big jump between the f35 and 45 in the same size, but if one moves up to the Ti L (large) in the f45 the jump from 14.7 ft to 16.6 ft is less than 9lbs, although to go to "L" in the same size jumps nearly 20 lbs, so from a weight standpoint the f45Ti in 450cm seems to be the best bang by the pound.
However what I really want to do is something like dual f45 Ti L 550s, which would add 100lbs on each side, allowing me to redub my van "the green seagull". But seriously, would adding 200lbs up high on the van cause that much issue?
