Here's today's progress!!!
Note..my horn sucks...so its hard to hear..but after the swap I didn't have a horn in any configuration YET
I discovered the existing clock spring in my van was in good shape only missing one wire that the busted one from the donor didn't have..
Got it all apart..soldered in the missing wire..ran it thru the plug and connected it to the correct terminal..found the diagram and moved my green wide in the brown plug to match the wiring diagram...
Didn't work...
Moved it back...
Still didn't work
Downloaded the fuse diagram and poked a little but seems like everything's there..
Ran out of time...and figured out why my van is being slow to start sometimes...don't buy CHEAP BATTERY TERMINALS!! previous owner did..it melted as I was overdrawing power from drained batteries..heavy duty one in place now...starts much better..
Lets see what daylight brings..
Sent from my VS987 using Tapatalk
