I second Boywonders suggestion on the VIAIR, I have attached a link to the setup I just installed in my jeep. It runs $399 with tank compressor, gage, and pressor swith. It will give you air for tires pop-top, and with the tank, you can fill everything much faster and not have to run the compressor if rolling into camp late at night. My Sportsombile has both an ARB and Extream Air, mounted outside and doing great after 10years living in the elements, just follow the mounting instructions.
If you're not interested in all the installation work and plumbing. The Alumaness lift would be easily acuated with any portable 12v pump, some are very slowwwwww but will get there.
Depending on the model, compressors will draw 23-85Amp hours so always keep the engine running when in use.
https://www.4wheelparts.com/p/viair-..._/R-BKTN-10007
