Old 04-29-2012, 05:24 PM   #1
Aluminess standard box and gas cans
I just got a Aluminess rear bumper with the standard swing arm box . I am putting four nato or spectre style fuel cans on it. Has anybody come up with a trick way of securing the cans to the box? Right now I'm using two rachet straps and cable lock . This just seems way to generic for such a cool looking bumper.
2007 Ford E350 V10 4x4 Sportsmobile Clone
Wildhare is offline   Reply With Quote
Old 04-29-2012, 08:24 PM   #2
Tapatio's Avatar
Re: Aluminess standard box and gas cans
I installed 6 stainless steel footman loops and secure the cans with 1 inch nylon straps/cam buckles.
Callsign KK6GIY
Old 04-29-2012, 08:28 PM   #3
If nothing else, you can combine the ratchet straps and cable lock and get these. Locking ratchet straps, where the nylon webbing has a steel core running through it.
A bit pricey, and likely won't stop the determined thief, but a nice set up.
http://www.steelcore.net/products.html
Old 04-29-2012, 08:34 PM   #4
Gnarvan's Avatar
Being a boater I always seem to use a 1" cam buckle strap for all my strapping needs. The cam buckle is pretty stout and secure. I used a 1" cam buckle strap and a bicycle combination lock to secure my water cans to the top of my fuel can rack. Here are a couple of photos to show you what I'm talking about.
Right side showing the 1" cam buckle strap and the bicycle cable lock
Left side showing how the strap loops around the rack and heads back to the buckle.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 05-02-2012, 07:33 AM   #5
Thanks for the ideas. Those steal core straps may be the way to go .That would ease my concern about the sun rotting the straps and loosing the cans going down the road.
thanks,Wildhare
Old 05-09-2012, 07:54 PM   #6
mbachani's Avatar
FYI, I have two of the Steel Core Straps and they are not Ratchet Straps. They are just another locking device like the bike cable locks.
Bob in Tucson
2003 Ford SMB Quigley 4wd
Bob
mbachani is offline   Reply With Quote
Old 05-09-2012, 08:07 PM   #7
Also, the ratchet straps that truckers use seem to last years in the sun. They will discolor but work for a long time. Don't know what they cost, the company buys them for me.
Old 05-09-2012, 11:44 PM   #8
BIGVANS's Avatar
I had NRS sew up some ratcheting straps for me, they work great! I supplied them with the ratcheting buckles I cut off the double hook end type tie down straps. The new straps have no hooks so I can feed them through slots or footman loops and ratchet them tight.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Vanna
gahamby
Sporty Spice
Tapatio
