Old 09-30-2008, 07:26 PM   #1
anyone attached a hose from faucet??
hi there, has anyone connected a hose to the sink faucet?? no shower option on my newly purchased (used) smb. i want to be able to rinse off and was hoping to have a spray nozzle on a hose connected to the faucet. any thoughts/ recommendations?? looked for an adapter at the local big box hardware store, no luck yet. thanks in advance. frank
tampaliquors is offline   Reply With Quote
Old 09-30-2008, 07:31 PM   #2
Greg In Austin's Avatar
Could you replace the faucet with one that already has/is a hose attachment?
Greg in Austin
http://badge.facebook.com/badge/1232...3.32047100.png
Old 09-30-2008, 07:53 PM   #3
SMB West
Supplied an attachment for my new to me SMB, per previous owner. I have not used it yet, but it attaches to the stock faucet for exactly what you are wanting. Forgot to add that it has a shower head on it that has some flow controls.
Jim
Soloracer is offline   Reply With Quote
Old 09-30-2008, 10:07 PM   #4
zugg's Avatar
Hi Frank,
I had the same situation and found a great solution.
I bought a male adapter from ACE Hardware.
13/16" x 20 Thread.
It will screw on to your faucet, (once you remove the housing for the screen.)
The bigger thread will screw on to any garden hose.
I got a 4' long hose. Anything longer will tax your battery as the water pump works harder to maintain the pressure.
I bought a lever activated spray nozel attachment, with 5 different settings.
Set your desired tempature, and leave your water pump on.
It works great!
Good luck!
Zugg
Always do your best!
zugg is offline   Reply With Quote
Old 10-01-2008, 09:06 PM   #5
jlrray's Avatar
Send a message via ICQ to jlrray Send a message via AIM to jlrray Send a message via MSN to jlrray Send a message via Yahoo to jlrray
Yes.. You want to use a screw on socket type. I bought a slip on type and more often than not, it popped out with water spilling everywhere.
Joe
jlrray is offline   Reply With Quote
Old 10-02-2008, 12:13 PM   #6
I have used the same setup with the flat water hose that came with the van. Works great and that hose is 20 feet long. I use it to wash down a diesel spill if the pump overflowed or splashed diesel around the fuel door. I too had to take the screen out and install the adaptor.
Dave
Old 10-05-2008, 12:45 AM   #7
JoeyNick's Avatar
Re: anyone attached a hose from faucet??
Originally Posted by tampaliquors
hi there, has anyone connected a hose to the sink faucet?? i want to be able to rinse off and was hoping to have a spray nozzle on a hose connected to the faucet.
Yep. I did this a while back.
See this post for pics:
http://sportsmobileforum.com/viewtopic.php?t=682
-Joey
JoeyNick is offline   Reply With Quote
