Old 04-19-2012, 05:39 AM   #1
Anyone running 325/65/18 tires?
Trying to get any feedback on this size with regard to clearance issues.
Also any picture with this size on the SMB.
thanks,
carl
2010 SMB
Old 04-19-2012, 10:39 AM   #2
Re: Anyone running 325/65/18 tires?
I don't know the answer but I'll reply since no one else has
My guess is that since that's a 35" tire it should fit on an SMB 4x4 conversion but might not if it's a Quigley. It might rub on the sway bar but should clear the bushwackers.
2011 VW TDI Golf for hwy fun
Old 04-19-2012, 11:01 AM   #3
rockbender's Avatar
I don't know for certain either, but it would be the same diameter pretty much as a 315/75/16 that a lot of folks have used, just a wee bit wider. Wheel offset may come in to play with the wider tire too.
My comparison likely isn't too relevant since my van is from the dinosaur era, but I recently went from 315/75R16's on 10" rims to 295/75R16's on 8" rims and was able to adjust my steering stops a bit (ie have a slightly tighter turning radius now.)
Josh
Old 04-19-2012, 11:36 AM   #4
I don't know if it helps but you asked for pics so here's what my rig looks like with 315/75/16 Duratracs. The rims are ATX Mojaves which I think have 0 offset and I do get rub on the sway bar in a tight turn.
Old 04-19-2012, 11:47 AM   #5
I suspect at full turn a little rub on sway bar. When I look at current 295/70/18's at full lock, I have approx 1/2 an inch or slightly more.
I was hoping to see and speak with someone who has this size to really confirm.
thanks for input
carl
2010 SMB
Old 04-19-2012, 05:18 PM   #6
I run 35/12.5/18's on mine- no rubbing whatsoever. Pics in my gallery if interested...
tomesd is offline   Reply With Quote
Old 04-19-2012, 06:15 PM   #7
I couldn't help myself and had a gander at your gallery. Are those sweet looking rims the ATX Artillery?
Old 04-19-2012, 07:01 PM   #8
Good eye- I liked them so much I bought a set for my Tacoma as well!
