Old 07-25-2016, 08:42 PM   #1
chaos's Avatar
Boise, ID help, shop recommendations?
ID:	123781st week of a 3 week road trip from SoCal done...
Just rolled in to town after a week Whistler, BC.
~2200 miles logged. while unpacking my van at my sister in-laws place I noticed this leak coming from the rear driver side axle.
fluid isn't that thick. but I don't know the differences between gear oil and brake fluid.
I'm supposed to leave for Lake Tahoe on Wed morning to meet my MTB buddies to ride for 5 days while the rest of family stays in town.
then meet back up with them in Bend, OR but need to get this looked at and fixed...
any suggestions on where to take this in the Boise/Meridian area?
thanks!
chaos is offline   Reply With Quote
Old 07-25-2016, 08:48 PM   #2
BajaSportsmobile's Avatar
Check your Brake Fluid Reservoir, if it is low...
Brake Fluid will wash off with water, gear oil will not.
AgileOffRoad.com
Old 07-25-2016, 08:58 PM   #3
chaos's Avatar
thanks Ramesy!
I just did that. looks full...
took some brake parts cleaner and sprayed the area.
everything is coming off pretty easy
Old 07-25-2016, 09:00 PM   #4
Do you recognize the "sweet" smell of gear lube?
AgileOffRoad.com
Old 07-25-2016, 09:09 PM   #5
chaos's Avatar
can't say that I do
went back out to check for more leaks after spraying down and cleaning the area
seems to be a slow leak somewhere...
Old 07-25-2016, 10:08 PM   #6
it first looked like the brake line, possibly banjo bolt but then I got the orientation of the picture right and now I'm not sure...
Old 07-25-2016, 11:10 PM   #7
chaos's Avatar
Posting from my iPhone.... Fail!
Old 07-26-2016, 06:53 AM   #8
firedude67's Avatar
I use J's automotive, near downtown.
J's General Automotive & Diesel Repair – Full Service Repair For Your Vehicle
2083380123
In fact, Hercules is there right now for some work. I have had Josh brake work in the past. No complaints and treated me right. If you need someone to run you around or just want to grab a coffee/beer, shoot me a PM.
Good Luck!!!
firedude67 is offline   Reply With Quote
Old 07-26-2016, 10:37 AM   #9
chaos's Avatar
thanks for recommendation. much appreciated!
found out there is Ford dealer/service center under a mile away
took it here this morning and they don't have time to look at it.
by appointment only :/
at least they recommended a shop just down the street that could!
new shop believes it gear oil...
Old 07-26-2016, 10:42 AM   #10
rallypanam's Avatar
Well, I guess the next question is.. full float or semifloat rear axle?
