Old 09-22-2012, 10:31 AM   #1
cleaning penthouse plastic windows
What can I use besides soap and water? Is there anything you shouldn' use like windex etc....?
stanw909 is offline   Reply With Quote
Old 09-22-2012, 11:40 AM   #2
Re: cleaning penthouse plastic windows
I used a 3m plastic polish.
I got it from a shop that sells automotive painting and repair supplies. It is used on convertible top windows.
Old 09-22-2012, 12:59 PM   #3
NRL
NRL's Avatar
Send a message via Yahoo to NRL
I've been using moisturized aloe baby wipes. Works for me.
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
NRL is offline   Reply With Quote
Old 09-22-2012, 02:42 PM   #4
I haven't needed to clean mine yet, but I second this. Much milder on the plastic I bet. Mostly I just vacuum the bugs out of the bottom of mine. I never knew a pop top would be such a bug trap but it is!
Old 09-23-2012, 06:32 PM   #5
BIGVANS's Avatar
Plexus
http://www.plexusplasticcleaner.com/about.html
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 09-23-2012, 07:05 PM   #6
Originally Posted by BIGVANS
Used this for years on my motorcycle faceshield, and for about 10 years on my Bronco's soft-top. I won't use anything else on plastic windows.
Old 09-23-2012, 07:07 PM   #7
Cool, seems like I used to see it in stores but not in a long time. Where can you get it besides ordering?
Old 09-23-2012, 07:10 PM   #8
Tapatio's Avatar
Most motorcycle shops carry it.
Callsign KK6GIY
Old 10-28-2012, 12:08 PM   #9
moorefc's Avatar
Have found great results with
http://303products.com/index.php/protec ... cmfqsvmp20
Boat industry uses it for vinyl. It also works great on the zippers, since it is (I believe) a water based silicone, so the zips are like new. It leaves a slippery surface that can be wiped down easily.
This infomercial is a bit heavy handed on the add, but shows the product
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
Old 10-29-2012, 12:32 PM   #10
I have used Plexus on motorcycle windscreens and helmet visors for years. I've used it on the vinyl windows in our Sportsmobile for 4 years with terrific results. Easy to use and the vinyl windows end up looking like new.
oclv is offline   Reply With Quote
Jiminy
Gooseberry
Vanzilla
Glenn P.
