Old 06-25-2009, 01:49 PM   #1
mjeffrey's Avatar
Drilling into / through the top
I'm getting ready to mount my solar panel, and later a roof rack.
1) When drilling through the top to mount angle-aluminum, is there anything I need to watch out for? How do I avoid cracking the fiberglass - gradually increasing the bit size? Tape over the hole? What tips do you all have for me?!
2) When mounting roof racks (such as Yakima), how do you secure them? Are they drilled into the top, and if so, are they through-bolted or self-tapping screws into the top?
Thanks very much!
Mike.
mjeffrey is offline   Reply With Quote
Old 06-25-2009, 03:30 PM   #2
pjpvi's Avatar
Re: Drilling into / through the top
My rack bolts and bolts for the solar panel are all outside of the canvas side. It is a through hole with bolt/nut. I don't think I took any special precaution when drilling. The one thing I hadn't noticed prior to starting the project is that the top is not flat near the front and when I bolted down the angle aluminum for the solar panel, I started hearing the crackling of the fiber glass as it was getting straightened out. I ended up spacing the aluminum up in the front. I think the proper way is to use aluminum angle "feet" instead of a long length of aluminum. Of course I think this only applies if you are at the far front of the top.
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 06-25-2009, 06:11 PM   #3
I believe John K. gave a good description on installing Thule tracks in this post.
viewtopic.php?f=2&t=1031
Old 06-25-2009, 10:55 PM   #4
mjeffrey's Avatar
Thanks both! (and John K )
Ford Zilla
Steve C
Rosy
Isever
