Old 12-11-2017, 12:39 PM   #1
4x4sporty's Avatar
Espar ?
Any one using Espar B4 gasoline heater? If so is it reliable? Can you heat water with if also? How complicated is installation?
https://esparparts.com/espar-airtron...r-p-25395.html
4x4sporty is offline   Reply With Quote
Old 12-11-2017, 12:46 PM   #2
Flux's Avatar
Does not heat water. Installation same as any other. Hardest part will be dealing with the fuel pickup. You need to get a pickup to the tank. Some have put them on the fuel pump assembly, others have drilled a hole in the tank and installed. Gas fumes are dangerous so drills and such are dangerous around them. Read up on that if you intend to DIY that portion.
Install is not that bad, just takes planning as you have an intake, exhaust and fuel line on the outside. Mine works great. I suspect it is not more or less reliable than the diesel versions, maybe more so since gas burns cleaner, but that is speculation. A B4 would keep that fixed top very toasty.
<br>
Old 12-11-2017, 12:50 PM   #3
4x4sporty's Avatar
My fuel tank has a pick up already in the tank for generator.
Old 12-11-2017, 12:59 PM   #4
Flux's Avatar
Then you are half way home!
<br>
"Swedish DoKa"
BigBrap
Van22
Van22
