I just has a wonderful trip in Southern Oregon and Northern California. While visiting one of the fire lookout towers experienced a flat where a rock placed a dime sized hole in the middle tread of my Toyo MT 295/75/17. My patch kit did not have directions but was able to figure it out enough. However the hole was too big for the plug I attempted to use and a patch would have worked better. Problem is I did not have tire spoons to pop the bead from the rim.
I feel I need tire repair 101, since I did not even think of spoons to pop the bead. My question here is what spoons or other method do you use? When do you use a plug? There is grease for the plug to thread the tool to place the plug. However it makes more sense to coat it in cement to galvanize the plug to the tire.
You can always pop the tire off the bead by driving onto the deflated tire. Getting it to seal and pop back on can be an issue.
A great trick to set a bead on a tire is to use a small amount of starting fluid spayed into the tire then light the starter fluid. The fluid will explode and set the bead.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Re: Field Flat Repair
That is a cool attachment. I've used just a Hi-Lift many times and they work great on their own but that tool would help.
Twist multiple plugs together for big holes, even in sidewalls for temporary use.
Now would a patch suffice if there was a dime sized hole that cut three bands or belts of a ten ply tire? Or is the tire shot? The defect is mid tread middle of a traction lug surpri
singly.
'95 SMB E350 Quigley 7.3 https://www.taylorarts.com
I might drive out of a trail on a repaired tire, but it will be replaced ASAP. I think driving on a repaired tire with a heavy vehicle is bad mojo IMO.
