Well, as luck would have it.....I had my first blow out this weekend on a set of tires that was less than a week old. Figures.
I hadn't even had a chance to put my "jack plan" into action. Must have hit a bolt or a BIG nail because the hole it made was big.
Thankfully, my GF has AAA so we called them really only for the use of his floor jack.
It will be interesting to many that even with the floor jack, we could not jack up the van until we filled the tire (even though it was leaking quickly) and then stuck the floor jack under the axle and started a'pumpin'.
With the tire flat, there wasn't enough clearance under the van to be able to raise the handle high enough to get purchase. Once we raised the van slightly by airing the tire up we had enough clearance.
Its also worth noting that with his floor jack, it took BOTH of our combined weights (estimated at 500+lbs) to get the thing jacked up high enough to change out the tire and even then, I had to air down the spare. I tried to see what his floor jack was rated but couldn't get that. I suspect 6 tons.
This was on FLAT ground on asphalt!!! A very enlightening experience to say the least.
I think I'm going to stick with the 2-stage bottle jack idea but I'm certainly going to give it a test run in the driveway to get the process down pat. I ended up plugging the blown tire just in case I got another flat in the backcountry but I have to say I don't think the stock Ford little cranker-jack was up to the task if I needed it.
If you have a situation where you can't air up the flat tire (massive blow out or off the bead) then it might get a little difficult.
Of course, all of this was in 60mph winds near Mojave, CA. Let me tell you something, when the tire goes flat on these things (especially heavy versions like mine) the whole experience gets pretty squirrelly pretty quick. A sphincter-tightener for sure.
Thanks to all for their input. Hopefully I won't have to report that I had to put my plan in action again......
