Old 07-30-2009, 10:04 PM   #1
Gray Water T Handle
Anyone that has a Gray water tank , you should check the T Handle to make sure it is secure .
We lost ours on the road last week , and it was seemingly tight when I drained the tank several times while on our trip . I ordered a replacement and a spare from Peter . He suggested the possibility of a little appropriate adhesive when replacing .
Greggde
Old 07-31-2009, 11:52 PM   #2
Re: Gray Water T Handle
It spun off???
Old 08-01-2009, 07:26 AM   #3
Apparently so Daveb , I noticed that it would swivel a little when actuated/pulled and thought that was part of its operation like knife valves that we have had on other vehicles . This T handle should be snug on its shaft , so a little adhesive will be used on the replacement .
Greggde
Old 08-01-2009, 08:42 AM   #4
My grey water drain valve is a brass lever valve that was (I'm guessing) moved inside by the PO. It's convenient to have it under the sink, and no parts to lose that way.. although I have lost the hot water-line drain valve that way.
Old 08-01-2009, 11:10 AM   #5
geoffff's Avatar
Originally Posted by Greggde
Anyone that has a Gray water tank, you should check the T Handle to make sure it is secure. We lost ours on the road last week
Mine worked its way off, too -- and I ended up using a little pair of vise grips instead for almost a year before I got around to buying another handle. The handle is cheap enough, though.
-- Geoff
2004 Ford, SMB 4x4, RB-50
The Hulk
Hulk
The YURT
MKRyan
