Old 11-11-2019, 10:45 PM   #1
CDACamper's Avatar
Heater Test
I'm trying to test the heater in 2001 SM. Turning on the switch at thermostat and when turning up the thermostat the fan clicks on but no heat. Does this valve need to be opened at the propane tank? Odd to me that there is the word "Vapor" under the valve and I'm nervous about what it's for
Here is a photo of the propane tank with the valve circled in red.
https://photos.app.goo.gl/PPs4BPyzgyk1jaAs9
CDACamper is offline   Reply With Quote
Old 11-11-2019, 11:42 PM   #2
dhally's Avatar
Yes that valve needs to be open. Then close it while travelljng. It may take a while for the heater to light up after the valve is open.
2009 E250 RB 5.4L "SilVan"
Old 11-12-2019, 08:33 AM   #3
As stated before that’s the propane shut off valve. It needs to be turned on. Also as stated before it may take awhile to light after the valve is on. Normal devices run off propane vapor not liquid. I believe vehicles, forklifts etc run off liquid propane that’s why it’s labeled that way.
Nrobert10 is offline   Reply With Quote
Old 11-12-2019, 08:55 AM   #4
You may need to purge the supply line by starting it four or five times in a row before it will light. This is pretty normal when they have sat for a long period of time.
Old 11-12-2019, 09:22 AM   #5
CDACamper's Avatar
Great, thank you for the info. I will give it a try. Thanks again for the quick reply!
Old 11-18-2019, 05:18 PM   #6
They start better if the tank is full...........
HIGHCOUNTRYMIKE is offline   Reply With Quote
Old 11-18-2019, 06:19 PM   #7
CDACamper's Avatar
Got it going. Was just the shutoff valve.
The Yeti
TexGX
Queen bee
Deaner
