Old 03-29-2016, 11:44 AM   #21
I've seen heater exhausts installed under the van, but those were diesel fired. Suburban's normally have the intake/ exhaust out the side. You mention "replacing" the thermostat, and also "I don't see any evidence of anything resembling a thermostat" Could you clarify exactly what you installed? You can also follow the line from the propane tank, if you have a heater, there will be a branch to the stove, water heater and furnace. Meanwhile, I'm considering upgrading to a diesel heater and may have a Suburban propane for sale. It works just fine, but is a bit underpowered for those days when the temps go below 0........
Old 03-29-2016, 12:54 PM   #22
I had issues getting mine to start and ended up finding a Suburban rebuild kit. After doing that if fires up right away every time. It was really easy, it even came with a cd-rom step by step but I didn't even need it since there really aren't that many parts to the system.
skiingjohn is offline   Reply With Quote
Old 03-29-2016, 07:00 PM   #23
Yeah, sorry - mentioned that above. Type. "anything resembling a furnace or outputs. Keep me in mind if you do end up selling it. I figured maybe there was some other config here, but I did a little more digging into the original paperwork (it was purchased from Indiana SMB) and no heat option. Again, I thought it strange but this thing originated in Delaware and maybe the A/C was the primary concern. It is in Colorado now at 9200 feet so some early morning heat would be much more appreciated than A/C, but oh well.
I'll have to check my gas line situation as I see there are some relatively inexpensive new heater options:
https://recreationpro.com/products/s...FQQbaQod7rQJpw
But if there is no heater I'm doubting anything got stubbed out to the passenger dinette seat to make the job easy.
Thanks for responding.
SuperG is offline   Reply With Quote
Old 03-29-2016, 07:02 PM   #24
Geez, I'm fat-fingering this thing right and left.
Typo. " "anything resembling a furnace or outputs."
Rex
Tomboy
Overland Van
TPowell
