Old 06-10-2010, 10:56 PM   #1
12bproper's Avatar
Highlift jacks, useful or useless?
I see some rigs with highlift jack mounted on them. These rigs seem really nice to be using these jacks. I witness what these jack can do and most of the time they do damage to the vehicle (rock crawlers that are pretty bang up anyways). So I ask, do people actually use these jack on there rigs?
2003 e350 ext. 7.3 psd, keeping it prerunner-added python remote start, buchwackers fenders, pro comp rims 17X9 steel, nitto grapplers AT 34s, camburg suspension 6", deaver rear springs, alluminess nerf, ladder, rear bumper, galley box, spare rack. Working on: arb on board air, rear locker, and 410 gearing.
12bproper is offline   Reply With Quote
Old 06-10-2010, 11:56 PM   #2
Re: Highlift jacks, useful or useless?
The "Search" button is your friend...
viewtopic.php?f=3&t=4294&hilit=Highlift+jack&start =30
Current: 2014 15 Passenger V8
Former: 2009 SMB 4x4 6.0
Old 06-11-2010, 08:00 AM   #3
Beyond using a Hi lift as a jack, you can use it as a come-a-long, a vice/clamp, and use it to straighten bent things.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 06-11-2010, 08:35 AM   #4
yvrr's Avatar
Yes, you need to be very careful in using them but if you've dropped a tire in a deep rut or hole, you may be in a position where you can't get a bottle jack under the axle. I've never had to use mine but I won't want to be without it.
Jack
'01 Ford EB50p Quigley 4WD
Old 06-11-2010, 09:24 AM   #5
The main function of my highlifts is to sit- I've managed to stay out of situations where I might need them, which has been an active goal of late. However I used one just the other day on the van to get some clearance for my battery project, and I used to use them all the time when getting stuck was fun, back in my Jeep Cherokee days.
Still, I have yet to devise a mount for the van, even though I have a separate hi-lift ready for it when I do.
Old 06-11-2010, 03:32 PM   #6
panion's Avatar
I'm not a big fan. The weight and lack of jacking points of these vehicles made me give up my high lift. Made perfect sense with my 3000 pound willys jeep, but I don't want to be anywhere near a high lift picking up ten thousand pounds.
Tom.
2001 RB 7.3 Powerstroke 4WD.
https://sportsmobile4x4.blogspot.com/
panion is offline   Reply With Quote
Old 06-11-2010, 11:07 PM   #7
I have used my Hi-lift several times to help with the weight ratio. I usually place in under a bumper to get some weight off the axle so that I can place a bottle jack under the axle to change a tire. I have used it as a come-along, or bend distorted metal. believe it or not I have used it in my profession to extricate people out of mangled cars after being involved in a wreck.
lazzboy is offline   Reply With Quote
