Old 06-03-2017, 08:26 AM   #1
Hoop steps repainting
Hey, all: My black hoop steps need refinishing after 15 years. Most of all they need repainting. What should I use on these? Thanks! - Rusty
2003 EB350, 7.3L, SMB 4x4, "50" w/propane
Rustywolf is offline   Reply With Quote
Old 06-03-2017, 11:15 AM   #2
Based on your username....I'd go with Rustoleum
Do you have an air sprayer?
If you have a means to spray you could consider a catalyzing 2 part automotive paint.
If not any rattlecan enamel is your only choice, although the best solution is likely having them stripped and powdercoated.
Old 06-03-2017, 11:32 AM   #3
rallypanam's Avatar
I agree with BW. Best/most expensive is powdercoat. Cheap and easy is a can of Rustoleum, which also allows for easy touch ups.
Old 06-03-2017, 12:51 PM   #4
MadScience's Avatar
I had a flat black bumper on a Montero years ago. I just hit it with a rattle can once every year or tow, or whenever someone ran into the back of it.
IMHO cheap and easy touch up is undervalued.
But yes, for something you step on regularly I'd find a powder coater. FWIW, there are DIYs for powder coating that don't look too bad at this point. I've not tried any, YMMV.
Old 06-03-2017, 02:03 PM   #5
gcvt's Avatar
I used Rust-oleum's Truck Bed Coating spray on mine and it's holding up very nicely. $7.50/can.
Greg
New van: 2003 E250 EB10
Old 06-03-2017, 02:33 PM   #6
A rattle can is nice and would be my choice for this instance. Powder coating has pros and cons it works in low traffic areas and places that won't see abrasion. Once it's scratched mouisture makes its way in and it's downhill from there. With a rattle can you can touch it up every couple years and your out $5 and 15 minutes.
Dai,
Dai,
Instagram @optoverland
Overland gathering every Wednesday at our workshop 5pm-9ish (40.60634, -105.078459
opt overland is offline   Reply With Quote
Old 06-03-2017, 03:18 PM   #7
FWIW, I've "touched up" old powdercoating on a roll cage with black Rustoleum. Not a perfect match, but I wanted to protect the exposed areas.
