Re: Ignition Chime
Piece-a-pie Patrick.
Just remove the three screws that hold on the cover at the bottom of the steering column. Then unscrew the lever that adjusts the steering wheel angle. There is a black wire with a pink stripe coming out of the ignition switch and going into a loom. Just cut the wire and all will be quiet. I'd clip it in the middle so there's enough to splice it back together, just in case....
Scatter
2007 RB50, 6.0
K1WGB
