Old 05-10-2008, 08:38 AM   #1
Light Security
Looking at Jayson's removable light setup got me to thinking about light security- how does everyone keep their lights from getting unbolted and disappeared?
Old 05-10-2008, 08:59 AM   #2
Greg In Austin's Avatar
...make the van really tall.... ??
Our bar will lock down as a first measure of security.
The bolts that hold the lights on are between two mounting brackets and are behind the bar. To unbolt a light from the exterior will not be a simple thing. (I will post a pic when I can)
Greg in Austin
Old 05-10-2008, 09:14 AM   #3
Jage,
I used the security nuts listed towards the bottom of the linked page. A nice simple design, though kind of a PITA to install because of clearance issues with the bumper, especially while trying to keep the lights aligned. Though it can be a PITA, I feel that makes it that much less attractive to steal my lights.
Off the top of my head, I don't remember which size I ordered.
http://www.rallylights.com/hella/Lamp_Mounting_Kits.asp
Old 05-10-2008, 08:04 PM   #4
yvrr's Avatar
I would assume that parking in our driveway would be the most location most susceptible to loss (I actually never thought about it). We park our van with the Hi-Lift jack (which is mounted to the front bumper) within an inch of the garage door. In this spot, it would be difficult (but not impossible) to get to our Hella lights. Hopefully, no one is interested in them enough to go to the work of actually unbolting them...they are also virtually hidden when so close to the garage door.
(To park this close to the garage door, I mounted a convex mirror on one of the rafter tails above and to the left of the garage door...this lets me see how close I am from inside the van.)
Jack
'01 Ford EB50p Quigley 4WD
Old 05-11-2008, 07:21 AM   #5
alta825's Avatar
Jack-
Do you guys also have the Reunel front bumper on your 01? If so, how did you mount the Hi-lift?
thanks
-d
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 05-11-2008, 12:23 PM   #6
yvrr's Avatar
Originally Posted by alta825
Jack-
-d
We ordered our van with the Reunel bumper and Hi-Lift combination. I don't know if the stock Reunel bumper already has the "cut-outs" for the jack but, if so, it would be simple to drill and add the lock on the tube. Here is what ours looks like:
Hopefully, this photo might at least give you some ideas.
Jack
Old 06-02-2008, 10:31 PM   #7
Really simple. There's a sign hanging right next to my sportsmobile that says "If you can read this, you're in range".
Works well, go figure.
DUKCSUN is offline   Reply With Quote
Old 06-02-2008, 10:44 PM   #8
That's awesome.
Here are my lights currently:
I'm thinking about drilling the large bolt and running a cable, and putting a lock nut over the small bolt, however, there is still the cross bolt that holds the light to the mount (just outside the detail photo).
The good news is the lights are simple to remove- pull the cross bolt and unplug the wire and I can store inside the van. Not something I want to do regularly.
