Old 12-12-2014, 11:27 AM   #1
new tires and issues with wet highways
I just replaced my BFG AT's with Michelin LTX AT's. (285 75 R - E rated)
I hadn't gotten very good mileage from the BFG's and didn't really need such an aggressive tread. The Michelins were pretty highly rated so I thought I would give them a try.
I've noticed the Michelins are a bit noisier, but also noted that they're downright scary on wet roads at freeway speed. The Van sometimes seems like its floating and beginning to drift out of its lane. I keep them aired up at 55 in the front, and 60 in the rear.
Does anyone else run these tires, and has had the same experience?
thanks..
Tom
2005 SMB RB 50 4X4 w/ a 6.0 PSD
flyfisher is offline   Reply With Quote
Old 12-12-2014, 11:40 AM   #2
E350's Avatar
Re: new tires and issues with wet highways
Dang Buddy! We have gotten in excess of 70K miles with the Michelin LTX AT2's on my wife's 2000 Dodge Dakota 4x4 and have driven in snow and rain with no issues whatsoever. I only had a few thousand miles on the LTX AT2's on my 2002 E350 EB before I parked it due to clogged injectors but those few thousand miles were on 100's of miles of snow and ice with no issues once I reduced the tire pressure to what you described. And the LTX AT's on my 1995 Bronco have only a few thousand miles on them but we just got some rain in Nor Cal and they have no issues. On the other hand, I drive slow in the rain so as to avoid hydroplaning. Since, my experience is so different than yours I don't know what could be the problem. Please post your answer once you find out what the problem is.
Old 12-12-2014, 12:45 PM   #3
mikracer's Avatar
How many miles are on your new set of tires? I've read that some tires take a few hundred miles before having good traction in wet conditions. Not sure how accurate that statement is though.
Old 12-12-2014, 12:50 PM   #4
Agreed, new tires have mold-release compound on them that is very slippery at first, especially in the rain. Give them a few miles and hopefully they will clean up...........
Old 12-13-2014, 12:42 AM   #5
1der's Avatar
I think you should check your air pressure as well. 55 F / 60 R seems at least 10 psi too low for our vans and E rated. This may contribute to the wandering as the tires may actually be running more concave than they are designed to thus trapping water instead of shedding. Weight of the 6.0 on the front tires is not going to help either if under inflated.
Would love to hear what others think / are running. I find 65 front and 75 to 80 rear works well for us.
Old 12-13-2014, 08:15 AM   #6
REF
REF's Avatar
Send a message via MSN to REF
Been covered in other threads, but I think most would agree that running your tires at or near spec is not recommended or necessary and gives a pretty harsh ride, but it might help bringing them up a bit to help shed the water? I'm currently running around the same pressures as flyfisher on my toyo M/T's but have gone up on long highway stretches to reduce wear. While the michelins are good tires, they don't have a very high void tread pattern and not sure how they would deal with heavier rainfall and standing water at highway speeds. I guess it makes some sense about the mold-release compound, never knew that, I just thought it was a kind of factory glaze or oil to help protect the tires from the elements during transport and storage, but it is pretty slippery.
Old 12-13-2014, 11:15 AM   #7
RandallDee's Avatar
I had these same tires on a 94 4Runner I used to own. I had some of the same issues you describe. I live in NW Oregon and drove them in the rain all the time. I suspect that a tire compound that is designed to go 70k miles is going to make some sacrifices in some other areas. After owning those tires, I've shyed away from high mileage tires because they left me with the impression that a softer compound is going to help grip better in wet conditions.
2023 Transit AWD w/ Van Haus build.
73 BMW 2002 O=00=O
RandallDee is offline   Reply With Quote
Old 12-13-2014, 11:21 AM   #8
^ what he said. Soft compounds help in the rain too.. My sister puts her studless snow tires on in the fall as soon as the rains come, because they are far superior in heavy rain than her "all season" performance tires. I always get my M55s siped. It helps a lot on any moisture, wet or frozen.
My brother even switched his 30' motorhome to studless snow tires. He's only put on 20,000 miles in 4 years, so he runs into age issues well before wear issues.
Old 12-13-2014, 11:50 AM   #9
I have also had good luck with LTX AT/2 tires. Never have experienced the issues you describe. In fact I strongly recommend these tires.
However, I would think your pressures may be a little low for an SMB w/6.0 PSD. My van is not as heavy as many others and Michelin suggested 65 psi all around for me. Weigh you van front and rear and then either look at a tire inflation chart or contact Michelin for proper pressures.
Old 12-13-2014, 12:21 PM   #10
thanks for all the replies, I've got about 6,000 miles on them, and I'll air them up a bit. The SMB doorsticker was why I set them at 55 psi front and 60 psi rear.
Tom
Road Roamer
Road Roamer
Otter
