Old 07-25-2008, 05:02 PM   #1
OBD Connector Modification? 1995 Dodge B3500 SMB RB
Does SMB make modifications to the stock OBD connector?
The transmission service shop indicated yes?
gmac is offline   Reply With Quote
Old 07-25-2008, 09:24 PM   #2
OBD
Connecting to/modifying the OBD is not something SMB would have done in the conversion process.
John K.
John Kalmbach is offline   Reply With Quote
Old 07-26-2008, 11:29 AM   #3
OBD connection
Thanks.
I have learned that the ODBII requirement came in 1996 and only some 1995 autos have it. I learned I could get the codes using the ignition switch and check engine light via Dodge website.
As I figured I have no codes ... only the finish check code of 55.
My transmission issue (intermittent ) is still troubling.
I am still betting torque converter due to behavior.
It happens for very brief period after night of sitting and then only on very steep long grade?
I plan to install tran oil temp guage to monitor on trial trip.
I going to get tranny flushed and loaded witht he higher grade fluid ATf -4... like some other memeber suggested.
Thanks All for your advice.
Greg
