Originally Posted by Vanimal
Boywonder won't black pipe work for him as well? I believe it is slightly thicker than standard pipe! Although it is a welded seam, for this application black pipe is readily available at any home improvement store for those that are unfamiliar with Chrome Moly!
No it won't.....
Pipe OD's and ID's are different than tubing....so that's the first challenge.
Schedule 40 pipe is as follows...size is based on ID, not OD.
Pipe size:
1/2" has 1/2" ID and .840" OD
3/4" has 3/4" ID and 1.050" OD
The welded seam would be the second challenge. Pounding DOM seamless tubing into bent bars will be enough of a challenge on it's own.
...and if you are going to go thru the aggravation of removing the cross bars, use cro-mo tubing.....yield strength of cro-mo is around 70,000 psi vs low carbon steel at 40,000 psi.
If you choose to use low carbon steel go up a couple of wall thicknesses.
Seamless Cro-Mo DOM tubing is readily available from McMaster-Carr
