Old 09-19-2013, 12:35 AM   #11
Re: pop top tension
Being on even ground makes a big difference
Old 09-28-2013, 01:36 PM   #12
Re: pop top tension
Make sure there is a door open. This is cheap and works great if that's not enough.
http://www.homedepot.com/p/Keeper-Ratch ... kcu3SijhVs
tortorelli is offline   Reply With Quote
Old 10-03-2013, 11:56 AM   #13
Re: pop top tension
I'd second the suggestion of the Home Depot cargo bar. Mine lasted about a year but just gave on me. It stows easily, and comes in handy to secure stuff in the van while traveling, as well as a makeshift tent pole. You just need to use it for a minute or less to get past the initial heft of the penthouse, and then the springs usually lift it up. I still haven't found anything more convenient, although I keep looking for a screw type or scissor that would work with a drill running it. But everything else is cumbersome.
Rob
Old 10-03-2013, 12:55 PM   #14
Jeffrey's Avatar
Re: pop top tension
I just got the Aluminess unit (the small one). It is air operated and works instantly and smoothly. A bit bulkier than a screw type, perhaps, but a pleasure to use.
And, yes, always open the side door whey going up or down.
