Originally Posted by CDACamper
Boywonder, I was re-reading your post and can't exactly visualize what you are describing in this sentance:
"I put a triple layer of butyl tape in the front channels before screwing down the plywood strips. Two squares in each channel then the continual running tape across the front....my have been even more layers..it's been a while."
The gooey black stuff between the canvas and van roof is 2" wide butyl tape.
Butyl rubber is uncured/unvulcanized rubber..that's why it's gooey...and seals really well.
Butyl tape is available from Mcmaster carr (and I'm sure other places).
The channels in the front of the van roof need to be "built-up" with squares of butyl tape to allow the top layer of tape to be flat..before screwing down the plywood strips that retain the canvas to the roof.
It take multiple layers of butyl in the channels to build them up enough to get a flat layer of butyl to fasten the plywood strips to....
