I'm about to build a new floorplan with a rear dinette/bed. For those of you who have this in a Ford, can you give me the height of the seat bases on each side? I have the rest of my measurements worked out but am planning what I can store underneath. I know I will be adding 2-3" in hight for the foam cushions, I just need the wood box height.
Thanks
Thanks, no problem there. It's a home build and I'm not thinking anything but storage is going back there. My batteries are going underneath and furnace is forward. What I'm mostly wondering is it I'll be able to fit a cooler in the middle underneath, even if the table is dropped down in bed mode.
Anyone able to give me that measurement?
My SMB dinette is a little different than that. The table does not make into part of the bed.
13" to the bottom of the cushion, 18" to the top
The lower cushion pulls forward, and the backrest drops in behind it to make the complete bed when both sides are done. The sidewalls are recessed to make more room for head and feet. I'm 5'10" and it is marginal.
Mike, Thanks a lot! That's exactly what I was looking for. I like SMBs design there too, probably better than a drop tabletop since that makes for a tiny table. I plan to build a table I can use up front or in the back (or not at all), but I want it bigger than what would fit down there anyway.
Also, my rear dinette/bed will only ever be for one of the kids, so I'm not going to spend a lot of time trying to recess it in to the walls. They can just sleep at an angle, or go pitch a tent!
I have the double dinette that folds down to about a double bed. I'll try to get some measurements for you tomorrow. I think it has about 11-12" underneath from the floor to the bottom of the cushion.
