Old 12-09-2017, 08:55 PM   #1
4x4sporty's Avatar
Removing antifreeze from carpet?
Any suggestions for removing antifreeze from carpet?
I moved my heat exchanger inside under my bench/bed and had a small drip in the hose connection that I didn't catch.
I have a spot that is soaked about the size of a 5 gallon bucket.
I do have a professional carpet machine to extract with but not sure what type of chemicals to use or if just soak with water rinse repeat over and over would be best.
4x4sporty is offline   Reply With Quote
Old 12-09-2017, 10:25 PM   #2
Bbasso's Avatar
Extract as much as you can first then use a 50/ 50 simple green shampoo with then rinse, last shampoo with a 25% tide powder is what I'd do, safe but time consuming.
Rob.
Current:
And had three other E350s...
Old 12-09-2017, 10:39 PM   #3
I had some spill and never could get it out. I wound up removing and replacing the carpet.
Old 12-10-2017, 11:04 AM   #4
4x4sporty's Avatar
I found on a classic car forum a guy who contacted prestone and they recommend straight water.
I will let you know how it turns out.
Old 12-12-2017, 08:59 AM   #5
4x4sporty's Avatar
straight water over and over followed by a little simple green no oily feel and smells great
Old 12-12-2017, 07:21 PM   #6
Is the carpet installed in such a way that it's easy to take out? If so, you could just soak it in a kiddie pool several times in a row.
Old 12-12-2017, 08:29 PM   #7
joefromsf's Avatar
You know what's in a kiddie pool don't you.
2012 E350 RB XLT Wagon, Agile 4x4, SMB penthouse
joefromsf is offline   Reply With Quote
Old 12-12-2017, 08:47 PM   #8
4x4sporty's Avatar
Thanks for the replies. It came out no problem with straight water several applications and a simple green last application for good measure.
