Old 06-25-2017, 11:17 PM   #1
jeff00seattle's Avatar
Question Replace or Fix Propane Compartment Door
I have a Sportsmobile 2001 Ford EB 250.
I wish to replace or fix the outside Propane Compartment Door because the piano hinge no longer moves due to rust.
I have removed and tried soaking this compartment door in Blaster Penetrant, but it is still stuck:
https://www.amazon.com/Blaster-16-PB.../dp/B000I2079E
I have found on parts a replacement propane compartment door on sportsmobilestore.com, but it is unfinished metal and without seals nor trim:
https://www.sportsmobilestore.com/pr...nt-door-metal/
Is there a recommended alternative supplier that could provide a good condition finished door (white)?
Or is there another recommended way for loosening a rusted piano hinge on a propane compartment door?
Thank you
Jeff in Seattle
2001 Ford E-250 RB50
jeff00seattle is offline   Reply With Quote
Old 06-26-2017, 04:32 AM   #2
Mine came unpainted from SMB, but it did have the seals, trim, and latch.
Sent from my SM-G935V using Tapatalk
Old 06-26-2017, 08:10 AM   #3
Question
I appreciate your reply
The Sportsmobile site did not make it clear about having all the extra stuff such as the seals, trim, and latch.
How did you have the propane compartment door painted? At a shop or by yourself with a spray can? And if by yourself, was there any recommended pre-coating and/or paint you used?
Thank you
Jeff in Seattle
Old 06-26-2017, 08:48 AM   #4
rallypanam's Avatar
I think I have a extra brand new door from SMB lying around in my garage.. I'll look tonight and will be happy to get rid of it at a discount.
Old 06-26-2017, 08:49 AM   #5
rallypanam's Avatar
P.S. And as for your painting.. two options. Rattle can in your garage, or bring to a paint shop and ask them to spray it in an exact match to your paint code. Shouldn't be too expensive.
Old 06-26-2017, 10:47 AM   #6
I had my replacement door from Sportsmobile powder coated. Mine is white and it was an easy color match.
2010 V10 EB45 4X4
new2tx is offline   Reply With Quote
Old 06-27-2017, 07:16 PM   #7
rallypanam's Avatar
So I do have a brand new door, but don't have the seal.. but you can get one at McMaster-Carr. Make an offer if you want it.
Old 06-27-2017, 07:26 PM   #8
Originally Posted by jeff00seattle View Post
...The Sportsmobile site did not make it clear about having all the extra stuff such as the seals, trim, and latch.
I believe the Sportsmobile store website is SMBw only. You may want to check with the two other sites as well for the seals and trim.
Old 03-26-2021, 03:27 PM   #9
Replace Propane Compartment Door
We have a 1997 Ford Econoline SMB and I’m also looking to replace our 17”x8” propane compartment door. It still works but is rusting through. The link in this thread isn’t working for parts. Anyone have any idea where I can find one? Appreciate any ideas.
S.Berry33 is offline   Reply With Quote
Old 03-26-2021, 03:57 PM   #10
Twoxentrix's Avatar
Probably not very difficult for a reputable Welding or Sheetmetal fabrication shop to make a new one for you.
You may also try a search for "MARINE BOAT DECK ACCESS HATCH", there are a number that come pretty close to the size you're looking for....its a start anyway.
EDIT: I found a company a while back when I was searching for something - these are access doors for RV's:
https://www.rvshop.com/Doors-Compartment_c_1071.html
Tags
compartment, door, propane, replacement
Coddiwomple
Rpence
TBD
thatsandrea
