Old 01-21-2019, 04:15 PM   #1
retractable steps
I'm looking for any info on retractable steps for the side door of my Ford Econoline which has a 6" lift. I don't need anything electric, just something I can manually pull up and down. I'm thinking 2 steps would be adequate. I need something that the dogs can use to get in and out of the van. Any help would be much appreciated.
micahjbun is offline   Reply With Quote
Old 01-21-2019, 05:00 PM   #2
Twoxentrix's Avatar
Still contemplating do this myself, but thought I would still throw it out for consideration: I had considered mounting the end of a Hitch Receiver to the frame under my barn doors, and then using this BELXX Multi step (Intention was to keep the BELXX attached in the rear, and when I needed it for the barn doors I could easily move it to that location). 600lb capacity rating!
https://www.amazon.com/BELXX-Multi-S...&sr=8-12-spell
These were my alternates
400lb Capacity rating:
https://www.amazon.com/Heininger-306...8114422&sr=8-4
Amp 300lb capacity:
https://www.amazon.com/AMP-Research-...s%2C148&sr=8-1
This one is only rated at 200lb capacity:
https://www.amazon.com/PetSafe-Solvi...8114269&sr=8-3
If these dont fit the bill, look at some of the steps an RV outfitter offers - may be more along the lines of what you're envisioning:
https://www.etrailer.com/Accessories...SABEgIQZ_D_BwE
