Old 01-30-2017, 10:04 PM   #11
Bbasso's Avatar
i don't have enough info on the livewire system but it appears to display/ monitor. my sct is a basic version which is meant to alter the vehicles functions w/o displaying.
Rob.
Current:
And had three other E350s...
Old 01-30-2017, 10:12 PM   #12
Bbasso's Avatar
some basic info I could find quickly.
SCT Livewire TS Plus features:
https://www.sctflash.com/products/tu...czEaArks8P8HAQ
SCT Livewire TS performance programmer and monitors let you tap your ride's hidden performance and excitement! SCT Livewire plus touch screens are easy to set-up, use, and navigate to quickly upgrade your boring factory-calibrated vehicle computer for a high performance driving experience. Pre-loaded dyno-proven tune files optimize air/fuel ratio, engine timing, and fuel curves to maximize performance--horsepower and torque for hauling and towing as well as fuel mpg--while maintaining OEM reliability and drivability. These tuner kits are available for both gas and diesel vehicles plus they include a windshield mount to keep your data at eye level. You're not like everyone else and your driving experience doesn't need to be mediocre! Power tune with SCT Livewire TS Plus performance programmer and monitors.
* Color 4 in. touch screen display
* Rear view camera input
* Automatic on/off/sleep mode
* Holds up to 10 custom tunes
* Reads and clears DTC codes
* Built-in performance calculator
* High-speed data logging and monitoring
* User adjustable tune options
* User selectable graphics and gauge layouts
* User adjustable warnings/alerts
Pre-Loaded Tune File Adjustable Options (adjustable options are not available on all vehicles):
* Adjust for different size fuel injectors
* Disable CMCV to prevent CEL
* Remove, increase, or decrease vehicle's speed limiter
* Increase or decrease idle speed
* Disable traction control
* Add or remove timing by rpm range
* Add or remove fuel at wide open throttle
* Change transmission shift pressure - automatic transmissions only
* Set gear ratio to correct shift patterns and vehicle's speedometer
* Set tire size to correct shift patterns and vehicle's speedometer
* Stores vehicle's stock file before programming
* Supports and holds custom tunes
* Adjust electric fan engagement temperature
Custom Tune File Adjustable Options:
* Remove, increase, or decrease vehicle's rpm limiter in Drive
* Remove, increase, or decrease vehicle's rpm limiter in Neutral
* Increase or decrease the wide open throttle shift points of each gear individually
The ScanGauge.
https://www.scangauge.com/
Compatible with all OBDII protocols
More than 15 Built-in Digital Gauges
Check & Clear Trouble Codes
Multiple Trip Computers
X-Gauge programmable gauge system
Performance Monitor
MPG
Fuel Used
Max Coolant Temperature
Miles Driven
Max RPM
Hours Driven
Max MPH
Average MPH
Fuel Cost
MPG for current tank
Fuel Used on current tank
Tank to Empty
Distance Driven
Distance Until Empty
Hours driven on current tank
Hours to Empty
Average Speed
Fuel Used Cost
The gauge screen allows you to select and display 4 gauges at a time, so you can monitor the current operating conditions of your vehicle in real-time.
In addition to the standard set of gauges, ScanGaugeII also includes the exclusive X-Gauge technology. With XGauge, you can add additional vehicle specific
Rob.
Current:
Old 01-30-2017, 10:49 PM   #13
I especially like the SCT option to "Remove...vehicle's speed limiter". That's been a vexing thing ever since I got the van. It's a bitch when I pass a slow mover on two-lane 395 north of Adelanto and hit the limit in the opposing lane of traffic with headlights coming at me fast! Looks like I'll be getting the SCT Livewire and see what it monitors, then maybe get the ScanGauge if it offers more options. Someone here calls their rig the Money Pit. Indeed. Thanks again.
Jack K is offline   Reply With Quote
Old 01-30-2017, 10:56 PM   #14
Bbasso's Avatar
It can be done a bunch cheaper, if you're interested.
My setup is torque pro app (I see nearly everthing+CELs+ clearing) and the basic 5 Star Tuning (SCT device) w/4 custom maps w/ ability to alter some basic settings including speed limiter.
My total was well under $400 iirc.
Not fancy but effective.
Rob.
Current:
Old 01-30-2017, 11:09 PM   #15
Does torque pro app mean that it's smartphone-based? (don't own one - smartphone, that is - bit of a retrograde, I am). And CELs - these are codes? (I'm new to this terminology.) Am leaning toward just biting the bullet and getting the full package.
Old 01-30-2017, 11:19 PM   #16
Bbasso's Avatar
Iirc the Torque pro app can be used with a tablet too, and those can be found cheap on CL.
CEL= check engine light, which usually has an associated code attached.
Rob.
Current:
Old 01-30-2017, 11:30 PM   #17
Thx. The education continues... Didn't know what iirc stood for, either, until I looked it up. The acronyms are something else to keep up with these days for this geezer!
Old 01-31-2017, 04:22 PM   #18
geoffff's Avatar
Yes! For that reason (passing on 2-lane roads) I got an SCT tuner some years ago (the XF SF3) and a custom tune from 5 Star Tuning to remove the top speed limiter. Otherwise I still use a Scangauge for watching my engine.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Priscilla
DocMP
Tan Hot Dog
Jsweezy
