10-13-2008, 08:49 PM
Just go to the above link "MY ALBUM" (in blue letters) and click upload.. then select the file on your computer. Then it will show up in your album and you can copy the link in the box to the post your want it in.
Looking forward to seeing your mounting option.
10-13-2008, 09:02 PM
We mounted out scan guage on the dash without creating any holes in the dash, and the cable is out of sight also....
You can see a bit of the mounting here above...
...and below...
and I can get better shots if you want them...
Greg in Austin
10-14-2008, 07:38 PM
i think i got the pic-thing halfway figured out....my pics were too big last time i tried and i didnt know how to 'compress' them. they are for sure bad pics, but i think the install is really clean....anyway, i cant figure out how to add them to the post, so they are in the gallery.
Joe Skrivan
E-350 V-10; Penthouse, Custom Interior
10-14-2008, 07:50 PM
That is pretty clean.
To add a photo, put your cursor on the file name in the little box, then copy that file name, and past it into the post.
Greg in Austin
10-14-2008, 07:57 PM
lke this?
Joe Skrivan
10-14-2008, 08:03 PM
Skri,
Something is wrong, but I don't know what it is. I tried using each of your photos and one of mine and nothing worked.
I suspect something is temporarily out of whack.
or...not, since I was able to post the same photo....hmmmm
Here is your photo...
and the other too
This must mean that there is an account related setting to fix.
Greg in Austin
10-14-2008, 08:42 PM
ok..thanks greg. i;m sure it's just a matter of time and figuring it all out....
Off topic--- anybody heading into yellowstone this weekend (oct 18th)...see you there. should be really awesome---snow on the ground, wildlife getting ready for winter, road is clear, decent temps....
Joe Skrivan
10-22-2008, 05:52 PM
Greetings everyone. I have been lurking around here for a little while now, getting a lot of valuable info. So a big thanks to everyone here. I'm going to be purchasing a used '06 SMB very soon, and I couldn't have made an informed decision without this board.
Here's a little webpage I found some time ago that will calculate the percentage difference in tire sizes, the only downside is it only goes up to a 335, but for most, that should suffice.
http://www.miata.net/garage/tirecalc.html
06 SMB V-10 E-350 4x4 RB-50
-and a quiver of fiberglass and polyurethane foam.
10-22-2008, 09:10 PM
Skrivan you're format is correct but you're holding down the SHIFT key when you do a carriage return which creates a line break instead of a paragraph break.
To the naked eye it looks identical and the "Quote" button replaces the line breaks with paragraph breaks, but as far as the image parsing software your original post is all one big mishmash.
You can play around in the Test section and see if you can get it to work. You'll need it to post your Yellowstone pics!
