Old 06-15-2009, 05:58 PM   #21
SMBDAD's Avatar
Re: Scangauge question...
I went with the PVM and it seemed to work. What gauges do you guys monitor? I like the tach, trans temp so far. MPG is kind of all over the place but will keep it on just to see what I am doing going down the freeway. Need 1 more good one to watch.
2001 7.3 4x4 "Land Orca"
SMBDAD is offline   Reply With Quote
Old 06-15-2009, 06:25 PM   #22
Transmission temp
Water temp
Inlet air (When you are moving it's virtually identical to OAT)
Manifold pressure
and sometimes MPG
Bill
NO2B
Old 06-15-2009, 06:44 PM   #23
geoffff's Avatar
There are more than 4 that I like to look at. I basically always have LOD showing, usually GPH and/or MPG, and switch among the others:
  • LOD - engine load % (when it gets above 90%, expect the transmission to downshift)
    GPH - gallons per hour
    MPG - miles per gallon
    HPR - horsepower
    TFT - transmission temperature
    FWT - coolant temperature
    VLT - battery voltage
My rear view mirror shows the outside air temperature, so I don't use the Scangauge for that.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 06-15-2009, 09:22 PM   #24
See now I think MPG and especially GPH are pointless and useless. I slapped my SG in just before the last trip and I've gotten everything from 1.2 MPG to 28.4 MPG in high range (I'm ignoring the 9999 from true coasting) and the GPH changes more than twice a second- what's the point of either? No human mind can possibly interpret the numbers to anything coherent (especially GPH).
If they were cumulative sure, I could get an idea about how lead-footed affects my current trip, but I'd need a spreadsheet to analyze even a minute of travel.
Old 06-15-2009, 09:23 PM   #25
I usually monitor the following
Transmission temp
Water temp
Engine load
RPM
and sometimes,
Voltage
Inlet air temp
I haven't done the proper calibration to accurately monitor MPG yet.
Rob
2006 SMB 4x4, EB-51, 6.0psd
EMrider is offline   Reply With Quote
Old 06-16-2009, 01:18 AM   #26
geoffff's Avatar
Yeah, often not really all that useful short term. But when the cruise control's on (highway driving), the values are reasonably steady. And I like to see just how much my instant MPG changes driving in 4th gear (my top gear) vs. 3rd at the same speed and throttle input on the highway.
And GPH -- helps convince me to shut off my engine when I'm idling too long in traffic.
-- Geoff
Old 06-16-2009, 03:26 PM   #27
I still watch the MPG but it is what you guys say it is. But I was surprised to see what a little load such as my trailer does to the mileage. I live in a large flat valley, but if I were living in the hills I wouldn't use MPG at all. Because I have separate EGT, Trany, and turbo boost gauges all I really measure is water temp and voltage. Would love to have a oil pressure and oil temp selection on it. Heck I wish it had a clock.
Old 06-16-2009, 05:33 PM   #28
Incidentially my Scanguage II cable jack is in the side, so the cable comes out the end instead of the back- is there a way to turn the cable jack so it comes out the back?
Old 06-16-2009, 05:43 PM   #29
MikewTV's Avatar
Send a message via AIM to MikewTV
Mine came with 2 jacks, one in back and one on side.
Mike W
Pueblo Gold Ford EB 350 v10 with EB 50 floor plan & Quigley 4x4 from Huntington (aka: Minerva)
MikewTV is offline   Reply With Quote
Old 06-16-2009, 05:44 PM   #30
scatter's Avatar
My ScanGage, and I thot all others, has two ports. One on the end and the other on the back. You looked on the back side jage????
Scatter
2007 RB50, 6.0
K1WGB
