Old 05-09-2009, 02:57 PM   #1
Scangauge Troubles
I recently installed a Scangauge II with X-Gauge so i could moniter my transmission fluid temps, but when i enter the codes, the scangauge wont report any info for my temp. Any Ideas?
b & j
b and j is offline   Reply With Quote
Old 05-09-2009, 07:46 PM   #2
yvrr's Avatar
Re: Scangauge Troubles
Scangauge has two lists for Ford and two codes for the transmission temperature under Ford CAD (whatever that is). I had to try a couple dodes before the transmission temperature function worked. If you have a V-10, I can tell you the codes I used...
Jack
'01 Ford EB50p Quigley 4WD
Old 05-09-2009, 11:45 PM   #3
geoffff's Avatar
You want the codes from the "PWM" Ford section, not "CAN". PWM apparently means "Pulse Width Modulation", and CAN means "Car Area Network".
2004 Ford, SMB 4x4, RB-50
Old 05-10-2009, 09:04 AM   #4
well I got it to work. it would not work on PWM. There Is an ALT CAN code I missed. Now it works fine. Thanks
b & j
Old 05-10-2009, 11:45 PM   #5
geoffff's Avatar
Good to know! What year is your van? (Maybe PWM is only for older vans like mine...)
Old 05-11-2009, 01:01 PM   #6
Ours is a 2005, 6.0. I read in an old post that someone else could only use CAN for Trans temp
b & j
