Old 05-23-2012, 06:16 PM   #1
shower outlet control
Has anyone taken apart the shower control unit?
Mine appears clogged. When turned to "hot" the volume of water goes way down to almost nothing so no hot water despite it being in the line leading up to outlet. Cold works great.
Had same issue year ago and replaced it.
thoughts?
carl
2010 SMB
Old 05-24-2012, 05:43 AM   #2
Re: shower outlet control
Mineral buildup? Try soaking in vinegar or CLR
"What'$ that funny noi$e?
Old 05-24-2012, 04:30 PM   #3
Great idea.
will give it a shot
carl
2010 SMB
Old 05-26-2012, 10:08 AM   #4
found the problem.
When I winterized last fall I drained the lines back to the shower and even ran some anti freeze into the tanks, sink, etc.... one thing I did not do is run anti freeze "thru" the shower outlet controller and wand. That brass shower outlet seals up when you remove the hose and there must have been a little water inside that brass valve assembly that froze and pushed out hot water gasket.
operator error!
carl
2010 SMB
