I bought all my stuff from
http://www.affordable-solar.com/
TWICE, once in early 2009 for my VW Westy
and again in August for my SMB
Great folks
Helped with enginerring/load/design
They also have brackets to do a fixed mount as well
as permanant mount
Ships all from one company
They even took back a box of parts i found
after the build out that i did not use
I would use them again
bw
I agree, simple to hook up
Use the LARGEST wire reccomended from the panel to controler
and controler to battery
I used:
Kyocera panels
Blue sky controler
Sure Power Isolator
I also wired a "momentary" switch to hook up "starter" battery and "house" battery to start my rig in the event i run down starter battery. This is a built in feature in the Sure Power Isolator
ps
the isolator hooks to rig alternator
tells it to first fill up Starter battery
then when full, charge the House batterys
