Old 10-09-2015, 12:13 PM   #1
Sports mobile van floor question
Can someone post up some pictures of their sports mobile van floor. I'm going to be building up my floor and am curious how sports mobile finishes off around the back door, side door and between the cargo area and the cab area. Do they run the plywood strait into the cab and under the chairs? If so how do they build out under your feet when driving so that it's all level? Or do they just end the plywood floor behind the seats.
Thanks guys
Chris
Gh0ztkid21 is offline   Reply With Quote
Old 10-10-2015, 01:08 AM   #2
Re: Sports mobile van floor question
Hello, my flooring stops at the back of the front seats. Carpet from that point forward. At the side doors it stops flush with the edge of the step and at the rear doors the vinyl covering tucks under the OEM plastic door trim/seal. I can send pictures later if no one else beats me to it.
dar636 is offline   Reply With Quote
Old 10-10-2015, 08:49 PM   #3
Thank you i appreciate the reply. Yes i eould love to see some pictures if you could. Also do they use a marine grade vinyl? Do they glue it down or just staple the edges down?
Old 10-18-2015, 11:41 AM   #4
rltilley's Avatar
I have a lot of pictures of my van at the link below. There should be some that show the flooring. I do have the extra fitted carpet in there that may cover some of what you want to see.
https://roberttilley.smugmug.com/Cars/S ... /i-3nbWSrP
rltilley is offline   Reply With Quote
