Old 07-28-2019, 10:25 AM   #11
moorefc's Avatar
Installing the molding with the seam center top seems to be less visible as it shrinks and you compress it so it stays in the corners.....It will always shrink, and always pull from the corners over time.......As mentioned, replacement or splicing in a piece from another location are good options if the gap is annoying...
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
Old 07-28-2019, 05:10 PM   #12
BrianW's Avatar
Shrinkage is the worst...
Old 07-28-2019, 09:27 PM   #13
Try any of the wood working sites. Rocker comes to mind
https://www.rockler.com/plastic-t-mo...wide-x-12-long
Brianf7028 is offline   Reply With Quote
Old 07-29-2019, 07:47 AM   #14
TomsBeast's Avatar
I tried, but couldn't resist
"Like a frightened turtle..."
Old 07-29-2019, 12:04 PM   #15
gahamby's Avatar
Perhaps I should show the T molding some porn.
'07 GMC 2500 6.0
Old 08-02-2019, 12:59 PM   #16
gahamby's Avatar
Well I didn't need the porn. For the galley drawer T molding I put the molding in boiling hot water, clipped away some more of the T insert at the corners, applied Seal All adhesive in the slot in the MDF, pressed the trim in while stretching it, and drove a couple of bronze ring shank boat nails in on either side of the joint. I put a Pony strap clamp around the perimeter of the drawer face and left it over night. It seems to be well adhered all the way around with only a slight gap where the trim joins.
Seal All adhesive is readily available at auto parts stores.
'07 GMC 2500 6.0
Old 08-02-2019, 05:47 PM   #17
marret's Avatar
Cool, great info, thanks.
Chris
