Old 10-09-2018, 12:05 PM   #71
If you had to do it all over again would you consider a tall roof van over low roof with a pop top? I still have the option to go with a tall roof Transit rather than low roof with a pop top. I am not a big fan of the tall roof but given the trouble reported here maybe I should think about it.
jsmith is offline   Reply With Quote
Old 10-09-2018, 01:08 PM   #72
Hey jsmith. Yes, if I was to do it all over again I would go with a tall roof, given the cost and the craftsmanship of the poptop
Sunnyday is offline   Reply With Quote
Old 10-09-2018, 01:13 PM   #73
The pop tops also rattle and squeak while driving on our wonderful highways, and have more wind noise while driving, etc. But, it can be nice to zip all those windows down and get things opened up. Still not sure what we will go with on the next one.
Old 10-09-2018, 01:29 PM   #74
Yeah, mine has wind noise on the highway also, as the new gasket around the bottom of the top they're using is a harder material, so unless your top fits the profile of the top of your van perfect you're left with a gap between the top and top of the van, which creates wind noise
Tags
bad fit top
