Old 04-12-2010, 02:28 PM   #1
Mmnt's Avatar
Tire carriers for E350 1997
On my old E150 1986 was such piece on a back door, it normally worked.
On E350 1997 I want to use such fastening. I do not plan to make heavy rear bumper, but I want to remove wheel from under a body. I used 33", but spare wheel may be it is less.
I see in ebay and shop about such things:
http://www.discountvantruck.com/vantire ... rriers.htm
http://cgi.ebay.com/ebaymotors/Custom-S ... 4ce3380759
Back door loops Econoline 1992+ have other device, than in 1975-91. It is inconvenient for installation. I do not understand while - as this decision is made and as it works on new body.
Pls, tell - what to buy, to have reliable fastening (as it worked on old body).
E150 4x4 1986
E350 4x4 1997
Russian name road that place where are going to pass...
Mmnt is offline   Reply With Quote
Old 04-12-2010, 02:48 PM   #2
Mmnt's Avatar
Re: Tire carriers for E350 1997
ooooups...
I see the next theme...
viewtopic.php?f=2&t=4669
Also has soon found it:
http://www.sportsmobile.com/4_4x4bumpers.html
Only the price does not please... Especially with the account, that I should add to this price 12$x1kg =...
E150 4x4 1986
E350 4x4 1997
Old 04-12-2010, 03:42 PM   #3
Your second link (to ebay) has the right picture but the wrong price.
This has the wrong picture but the right price. I think the basic Surco tire carrier is the TF200 for the ford van.
http://www.racksforall.com/surcofordtir ... later.aspx
I have a 1995 and have mounted the Surco. It has advantages and disadvantages.
The biggest advantages are that it is cheap and simple.
The disadvantages are you have to drill 4 holes in your door and when you open the door, the larger tires run into the rear light (I have not broken mine yet-mostly just leave that door closed). I don't now how it would hold up to rough use but it is pretty robust/solid when the door is closed.
It is the opposite of the Aluminess tire mount in most ways but it does work well.
Once you move the tire out from under the van, you can cut out the big tire carrier and mount a storage box underneath.
Good luck.
Tom
Tom
Austin, Texas
1995 SMB E250
Old 04-12-2010, 04:12 PM   #4
geoffff's Avatar
FYI, I have Sportsmobile's Trojan tire carrier (the one designed to work without a custom bumper), and am not thrilled with it. With wear (bumpy roads), it tends to shake and sag over time.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 04-14-2010, 10:22 PM   #5
It seems like something you could fabricate- they are pretty much just a loop of metal supported by the door hinges and the door itself. I used to have one on my '79 chevy just like it so it's not a new concept. With shipping to Russia and fit issues for large tires, I would think building your own would be more economical.
Old 04-14-2010, 11:46 PM   #6
neeemo's Avatar
Anyone know how far back the aluminess bumpers go. It looks like the 92-07 E350's are pretty much the same, but I wonder if they are.
'02 SMB EB Q 4x4 Diesel
neeemo is offline   Reply With Quote
Old 04-15-2010, 10:34 AM   #7
Mmnt's Avatar
I already have assembled a few information, it is not pleasant to me. Fastening on old body was reliable as came directly on hinge strains. On new body carrier fastens for thin metal of a door, it is very bad... New door hinge strains hidden...
I think, I will made a design similar on Trojan. Thanks all for opinions.
E150 4x4 1986
E350 4x4 1997
