Old 02-22-2012, 11:52 AM   #1
Tires and Load Ranges
Hello all.
I am due to replace my tires for this years travels. I have 30K on my tires and they are below 50%.
My Nitto Terra Grapplers have served me well. Killer snow tires (on pavement snow/ice conditions).
285/70-17 is the size I will continue to use.
These tires are E rated as we all feel this is an appropriate rating for our heavy vans.
I am looking at alternative tread designs other than the Terra Grappler. More off road/mudder style tread (I will be in Colorado this summer).
Many I am looking at only come in the D rating. Rated at 3195 lbs per tire. I have even seen an E rated tire speced at 3195. My Terra Grapplers are rated at 3750 lbs per tire.
Nitto Trail Grapplers, E rated carry a 3195/2910 (?) weight limit.
Hmmm...
Goodyear Dura Trac, Mickey Thomson MTZ or Nitto Trail Grapplers are current choices among others.
My question is the fairly standard D rating of 3195 lbs per tire enough?
That would come to a total weight of 12,000 lbs plus for the vehicle on the D rating.
6000 per axle seems enough to me although the margin is lower than an E rated tire.
One difference of D to E rating is usually D rated tires accept up to 50-65 psi while E rated tires accept to 80 psi.
My QuadVan and fairly basic interior weighs in light compared to SMB's.
I do not overload factory weight ratings in vehicle or combined vehicle/trailer limits...
Thoughts on this?
Is the D rating giving enough margin?
Thanks.
maxacceleration is offline   Reply With Quote
Old 02-22-2012, 12:19 PM   #2
Re: Tires and Load Ranges
Have you weighed your van to find out what the actual weights (f/r, r/l) are?
Then add 20% to the right side for roads with high crowns.
Now, does the 3195# work for you?
Old 02-22-2012, 12:24 PM   #3
bratworst's Avatar
The Toyo M/T LT295/70R17 128P E/10 (33X11.50R17) is a 33.5" tire with a capacity of 3970 pounds.
bratworst is offline   Reply With Quote
Old 02-22-2012, 12:45 PM   #4
Lots of good info regarding tire pressure and load index in these threads. viewtopic.php?f=3&t=1582
http://www.sportsmobileforum.com/viewto ... =39&t=3496
2011 VW TDI Golf for hwy fun
Old 02-22-2012, 01:00 PM   #5
IMO, a less quantifiable benefit of E load rated tires is that they generally have more sidewall stiffness, which helps control vehicle body roll.
Old 02-22-2012, 04:13 PM   #6
Viejo's Avatar
If you do much off pavement driving, you'll also want an E rated tire for the extra puncture protection.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 02-22-2012, 10:37 PM   #7
I thought your van was on the light side? Hell I ran D's since new for over 30K and those were BFG's with no problems. Not saying that was wise; only they worked. E's will be a bit stiffer, but I like the extra sidewall protection E's offer.
Maybe something to sift through here:
4x4 TIRE CHOICE
viewtopic.php?f=3&t=6128
The best street / all around tire to drive on pavement, gravel, dirt, snow and ice.
viewtopic.php?f=2&t=5369
TreadWright Tires
viewtopic.php?f=2&t=5542
Toyo Open Country Backorder- Options??
viewtopic.php?f=2&t=5379
Michelin LTX A/T or the newer A/T2 ?
viewtopic.php?f=2&t=5255
Toyo Open Country Mud Terrain Review
viewtopic.php?f=2&t=4258
Toyo Open Country M/T
viewtopic.php?f=2&t=3394
BFG Tread Separation
viewtopic.php?f=8&t=1107
Advice On Replacement Tires BFG AT T/A KO (315/70/R17D)
viewtopic.php?f=3&t=5475
I asked Quigley about the largest tire/rim combo
viewtopic.php?f=3&t=5799
Anyone running Firestone Destination M/T's?
viewtopic.php?f=3&t=5625
Any opinion on winter tires?
viewtopic.php?f=3&t=5276
It's time to replace the tires that came on my 07 Quigley 4x4 van. What Size?
viewtopic.php?f=3&t=1549
Who is running 37s?
viewtopic.php?f=3&t=5005
viewtopic.php?f=3&t=4297
Suggestions for tire size for 17" rim in new 2010 EB 4WD
viewtopic.php?f=3&t=4948
Experience going from 33" to 35" tires
viewtopic.php?f=3&t=4893
Toyo PSI
viewtopic.php?f=3&t=4697
Quigley 4x4 tire size
viewtopic.php?f=3&t=4227
Open Country A/T from Toyo?
viewtopic.php?f=3&t=3858
BFG KM2 Mud terrain 255/85 16 load range E review
viewtopic.php?f=3&t=3126
E-350 4x4 BFG Tire Pressure education
Calculating height vs. tire size.
viewtopic.php?f=3&t=3728
4x4 Tires for all seasons
viewtopic.php?f=3&t=2823
What is your tire size without fender flares
viewtopic.php?f=3&t=3423
35's vs 33's
viewtopic.php?f=3&t=3298
Tires too Big for Aluminess
viewtopic.php?f=3&t=2377
4x4 in the snow with radial tires
viewtopic.php?f=3&t=2446
New Goodyear tires with kevlar
viewtopic.php?f=3&t=2525
BFG Tire Value?
viewtopic.php?f=3&t=2527
Another BFG gone bad!
viewtopic.php?f=3&t=2299
Toyo Tire Upgrade-4:10 gears OK?
viewtopic.php?f=3&t=1825
Nitto Terra Grappler tires: 285/75/16
viewtopic.php?f=3&t=1580
Toyo Tires / Noise Factor
viewtopic.php?f=3&t=1431
Tire Pressure - Highway
viewtopic.php?f=3&t=1398
Toyo Tires and Warranty
viewtopic.php?f=3&t=1329
Tire load capacity
viewtopic.php?f=3&t=316
BFG Sidewall Issues
viewtopic.php?f=3&t=942
One More Tire Thread -- Toyo M/T Specific
viewtopic.php?f=3&t=1004
BFG AT T/A 285/70/17 on a 07 Quigley
viewtopic.php?f=3&t=964
285/75 16's or 305/70 16's - what should I get??
viewtopic.php?f=3&t=705
Largest tire size on Quigley conversion? MT tire thoughts?
viewtopic.php?f=3&t=695
Old 02-22-2012, 11:13 PM   #8
Okay, okay!
Old 02-23-2012, 05:30 AM   #9
I have found the Nitto Terra Grapplers to be great on the road and less than ideal in any mud.
I would agree with most that you should run an E rated tire.
carl
2010 SMB
Old 02-24-2012, 10:16 AM   #10
I completely agree with Carl. I've been running Nitto Terra Grapplers (285/75/16, E) for about 3.5 years and 38k miles. It is time to replace them. Not sure what I will be getting yet either.
GIL
Manoel Brazil
Vandit
aarcaris
