Please visit our updated website: www.theuniversalcarrier.com
We have designed, patented and manufacture a Sprinter specific electric carrier with a 1700 pound capacity worm gear ram in the lifting tower. This carrier can handle up to an 800 pound Adventure bike or any type you may have as well as two bikes at a time in the 250-300 pound class.
We have just finished our parallelogram lift attachment to our UC-1 carrier tower assembly. This carrier can now be placed into the easy hitch between your boxes and tire needing only 5" width. This units parallelogram arms, (only 5" wide), will lower and raise away from the tower lowering the motorcycle carrier plate onto the ground to load then lift electrically to the raised position at any point you care above or behind the rear tire or boxes. This unit is also ideal for larger F-700 trucks with higher receiver assemblies and can handle the excessive weights.
Please keep in touch for the launch of this new addition to our Universal Carrier line.
The receiving vehicle must be class #4 or 5. We provide a top link and tensioner from the square tubing on the vehicle using the easy hitch holding pin to an eye on the tower frame. this is similar to a top link on a tractor, it tri angulates the load to the vehicle. Zoom into the provided pictures on my earlier post.
Could it handle a Harley soft tail heritage ? Not a full bagger ? Thanks
