Originally Posted by moorefc
You have a number of good inputs, but I wouldnt waste your time with PVA...To seal the edges use a thin epoxy such as west system. Look up PVA, and you will find lots of info such as (thesawguy.com)
Types of PVA Glue
- PVA - Polyvinyl Acetate: This type of PVA glue is used for book binding, box sealing, and used in paints. It's typically white in color and dries clear. It's permanent and remains flexible after drying, rather than becoming brittle over time.
- PVA Wood Glue - This glue is a yellow-based glue, used for wood-to-wood joining. This type of glue absorbs into the wood you put it on. This glue holds even better if you clamp the wood while the glue is drying completely.
- PVA Water Resistant Glue- This glue resists mildew and moisture, which are two major benefits of using this particular type of PVA glue. Do not confuse water-resistant with waterproof. This glue, if submerged in water, will not work as well. However, because this work is water-resistant, it can withstand inclement weather of all types. Titebond II and III are good choices for this type of glue.
I have experienced Sportsmobiles with MDF and the newer plywood like material (SMB Austin identified their source as Core-lite, from Dicor Products in 2015) the product may have sold and renamed as Dicor no longer lists it, but I tried to source the material from them in 2015 and they referred me back to SMB. Both have issues with end grain moisture swelling, the latter, much less. Best solution is to remove the panels and epoxy seal the sensitive edges...silicon, even on both floor sides won't be anywhere near perfect as a patch...Under t-molding you might get away with PVA...Obviously one can compromise in non water exposed areas, SMB uses fasteners, not glue generally and the panels are not that difficult to remove. Pics showing some swelling of outer laminate are from non edge sealed, RTV sealed (and RTV resealed) Core-lite. Too bad SMB doesn't seal the edges prior to install, but that costs $$....
Your van will last many years, and, when you wash the floor.............
Thanks for the info on the Core-lite. I found it odd that Sportsmobile seemed reluctant to provide a brand name to me for the panels they use.
After some testing, I've opted not to use the PVA glue at the seams of the loncoin flooring and panels. I have a wide assortment of PVA glues as I use them often, but as the source you provided points out, those that are waterproof don't really dry clear. I didn't like the look of the yellow seam using the waterproof PVA I had (Titebond II) so I ordered some Loctite waterproof silicone to seal the seams with. I think I'll use the yellow waterproof PVA glue for sealing the edges under the T molding such as the edge of my table top; I won't see the glue there.
I agree that removing the panels and sealing the cut edges is the best soution, but that would involve a fair bit of labor. I'd essentially have to dissasemble the interior of my van piece by piece. While the panels are simply connected together via angle braces and screws, I worry I'd introduce squeaks and rattles and possible compromise the tightness of the assembled cabinets if I used the same screw holes during reasembly. I'll use the silicone to seal the seams and hope it is a good compromise.
Yeah, it sure would be nice if Sportsmobile elected to seal the cut edges before they used the panels in their cabinets. I saw that there is some nice edging tape which you can apply with a hot iron that melts the glue on the edging tape and creates a waterproof barrier. It appears to be quick (no drying time) and easy to use and would make these panels vastly more water resistant that they are now. But as you pointed out, that would increase their costs.
