I also remember reading through a thread about chasing water intrusion, culprit turned out to be a bad inner fender pinch weld or something.
I found that my front drivers carpet was getting soaked from water following wires being fed through a fire wall grommet, sealed it up with a good dose of silicone, think that has solved my issue.
I have to check, but I think I ran the wire from the cell booster antenna through a slit in the driver door rubber boot wire chase, might need to seal that up a bit better too.
