Old 08-12-2017, 11:01 PM   #1
What to put under vinyl floor for cushioning
Just got around to putting in my 1piece vinyl flooring from front to back and after kneeling on the vinyl on top of the plywood I was wondering what I could put between the vinyl and the plywood that will coushion the floor a bit to make it easier on the knees. Has anyone ever did that before? Would a foam work best or rubber? Maybe a neoprene type material? Maybe even just a carpet base like Ford applies to their factory vinyl flooring?
Thanks for all the help
Gh0ztkid21 is offline   Reply With Quote
Old 08-12-2017, 11:09 PM   #2
Bbasso's Avatar
Water ever you use make sure it won't absorb moisture /water or you're looking at rust shortly.
Rob.
Current:
And had three other E350s...
